Rockshox 20mm Maxle...
[Closed] Rockshox 20mm Maxle- lever 'floppy'/wont hold allen keyed retension
 hora
Help.
The lever basically hangs and flays around when riding. The axle is screwed securely in place/no probs. Every so often I'll tighten the allen key bolt in the centre to nip it up- but after a while the lever loses all tension again.
Any fixes before the lever off?
Posted : 07/06/2013 3:20 pm
I think you need the lever to give some resistance to get the maxle collar to expand and grab the end of the leg (the collar has a slot in it allow it to expand).
Yeah normally tightening/loosening the grub screw does the trick.
Dunno why it keeps coming loose for you.
Posted : 07/06/2013 4:06 pm
They're shit at staying tight, simple as that. It must be because they dropped the opposing end nut off the Maxle as the Maxle I had on the Pikes was rock-solid.
Mine has done the same since new (bought 18m ago). Once tightened, close the lever so it's in front of the fork-leg so it can't move back.
Works for me.
Posted : 07/06/2013 4:42 pm
Take it apart, apply thread lock to the offending thread. Jobs a goodun for a while.
Posted : 07/06/2013 4:49 pm
 hora
Goodpoint will put the lever infront of the leg
Posted : 07/06/2013 5:11 pm
