can someone tell me. Are these rforks the travel adjustable version?
http://www.chainreactioncycles.com/Models.aspx?ModelID=54604
Rock Shox Revelation RLT Dual Air Ti Forks 2011
No you need the dual POSITION airs if you want to adjust the travel.
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=54605 ]These[/url]
On one have got them cheap but only in QR.
As above
Aren't they internally adjustable via adding/removing spacers in the air spring like old Revs then?
Asking cos I was looking at a pair of these for myself, but would want to run them at 130mm on the current frame.
AFAIK they're still all-travel, so adjustable with spacers. For external on-the-fly you need dual position or u-turn.
It seems they are, I've just seen it on the Jenson website - internal spacers give 130,140 or 150mm
I consider 'adjustable forks' to just be a switch or U turn type control.
You can adjust travel on all of them
