Thinking about a set of these forks but could someone tell me if they have adjustable travel? i like having the ability to change setting when climbing..
Nope. Iirc that's what the solo bit means, one travel setting, 'dual air' has 2, uturn is unlimited.
Dual positon is are the travel adjustable model of the RCT3 Revs.
You can change the travel on the solos but you have to buy a different internal part in the size you need.
It's late and I'm not describing it very well. But you can change the travel, just not easily or on the trail.
Nope the Solo bit means there is just one air valve that you use to pressurise the air spring and it automatically sets the negative and positive chambers.
Dual Air is the old air spring that Rock Shox used to use. This had two valves so you could set the positive and negative chambers independently.
Uturn is the old Rock Shox system for travel adjust they no longer make this systemr.
The new system for travel adjust is call Dual Position.
Cheers for clarification. . ๐
Have some 150mm brand new 2013 RCT3 solo air with tapered steerer for sale
