Rock Shox PIKE 454 ...
[Closed] Rock Shox PIKE 454 110mm - 140mm question
Hi thinking of buying some of these
Rock Shox PIKE 454 110mm - 140mm U-Turn i have a set of hope hubs on dt swiss rims the hubs are pro 2s, i currently run a qr for the hub but was wondering if i can run the pike fork with this hub as i see it has a much bigger axle? Thanks
Posted : 29/09/2011 1:20 pm
What's the hope hub?
If its a proII it should be convertible to 20mm which is what you need for the Pike
Posted : 29/09/2011 1:22 pm
Pro 2 front hub about 2ish yrs old
Posted : 29/09/2011 1:29 pm
Yep, you can get adaptors for circa £15. make sure you get the ones for the ProII though.
Should be absolutely fine.
Posted : 29/09/2011 1:32 pm
