Rock Shox Air Shaft...
[Closed] Rock Shox Air Shaft Q- 2018 Debonair in 2016 Pikes?
 Alex
Need to change the air shaft in my 2016 27.5 pikes. 150mm required. It’s already had the damper upgrade. Worth spending the extra fiver for This one ?
More importantly will it fit? Not sure the Pike chassis has changed much in the last couple of years, but before I make that assumption, does someone have real world experience? Ta.
Posted : 24/03/2019 8:16 am
Yes its worth doing for sure, probably more so than the damper. However you need the version for 2015-17 pikes.
Posted : 24/03/2019 8:18 am
 Alex
Thanks Ben. I just realised that having done some actual research rather than guessing 🙂 I’ll ask Jake at Sprung to get me one…. probably safest.
Posted : 24/03/2019 8:28 am
 Alex
Update: Sourced one (from TFT in the end). I was tempted by those Fox 36s on the PSA but felt £42 was a somewhat more appropriate outlay considering I actually had a set of forks already!
Posted : 25/03/2019 3:57 pm
