Rock Shox 32mm seal...
[Closed] Rock Shox 32mm seal fitting tool
[#3208867]
Anyone have any recommendation's for fitting 32mm stantion seals? Am a tight git and dont want to pay for the official tool.
Posted : 04/10/2011 9:24 am
an approiatte sized socket normally does the trick
or a cut off of waste pipe
Posted : 04/10/2011 9:26 am
Push it in with your fingers!
Posted : 04/10/2011 9:29 am
Liftman what size does you socket set go up to?
I'd assumed some plastic plumbing tubing would work.
Posted : 04/10/2011 9:34 am
I did mine for the first time at the weekend. For the oil seals I used a bit of 40mm pvc wastepipe. A 32mm socket will also work. Bit of grease on the outside + popping them in the freezer beforehand and they went in nicely. The grey dust seals you can just push in with your fingers.
Posted : 04/10/2011 9:38 am
Thanks for this
Posted : 04/10/2011 9:57 am
