Rock n Roll Extreme...
[Closed] Rock n Roll Extreme but longer lasting...
Before I order another big bottle of blue Rock 'n' Roll, has anyone found an alternative that runs just as cleanly but lasts a bit longer?
I don't want a wet lube that goes everywhere but I have had to re-lube part the way through longer off-road rides (I.e. Dorset Gravel Dash etc.) which I'd like to avoid if possible...
Moon on a stick?
Thanks
Posted : 02/06/2016 9:24 am
 Gunz
I've got no alternative unfortunately but could you tell me where you get the RnR from?
Cheers.
Posted : 02/06/2016 9:34 am
You cant have lube that runs cleanly and lasts.
If it runs clean it means its thin
If its thin it doesn't stick
If it doesn't stick it falls off
I tried a few of these expensive thin lubes and chucked them out pretty quick. Basically the same as no lube at all.
Use thick lube and regularly clean your chain with a chain device when it gets dirty (or whatever method you prefer)
There is no lazy option to a well lubricated drivetrain...apart form an Alfine of course!!!
Posted : 02/06/2016 9:53 am
Ribble Cycles have Rock N Roll Extreme Lube in stock.
http://www.ribblecycles.co.uk/rock-n-roll-extreme-lube-rock-n-roll/
Posted : 02/06/2016 9:56 am
Is there a technique to applying RnR? I tend to just slosh tons of it all over the place ๐Ÿ˜ณ
Posted : 02/06/2016 9:57 am
You use tons of it if you work according to their instructions. I found it expensive and average.
Posted : 02/06/2016 10:02 am
Thanks for the replies folks - I regularly degrease and clean my chain but much prefer RnR to finish line wet or something that sticks to everything!
I guess a middle ground between the two...
Maybe I should just put the wet lube on for the Big rides
Posted : 02/06/2016 12:19 pm
I've got love for 'Squirt' chain lube at the mo - sorta waxy...
Posted : 02/06/2016 2:22 pm
After trying everything under the sun, I always come back to RnR Blue.
Applied once every muddy ride or on alternate dry rides. Ace.
The only reason I looked elsewhere was because I couldn't get any. But it seems those days are over.
Posted : 02/06/2016 3:23 pm
