Road saddle- where ...
[Closed] Road saddle- where to start?
 hora
Ok last night I was in the saddle for 3hours continously. My sit bones felt like I was sat on a concrete surface. Even 30mins feels like Im sat on cardboard. I know saddles take a while but I dont want to be tied to a shop and one brand/a few choices at 70 £+.
So secondhand possible? Or do I really need the new saddle/trial route?
The bike came with a san marco thing.
Posted : 30/05/2014 5:55 am
Hora - I found that when I put on the same saddle as my MTB (SDG Bel Air) it was really painful. You don't use the same bits of your bum on a road bike so it does take some getting used to. I ended up with a mid nineties Flite Ti as my saddle. Maybe a good start would be a modern Flite as a standard choice?
Try a specialized dealership - they do the different width saddle and have test models to lend out you can try.
I think the main issue is that you just don't move round as much which is going to take some getting used to.
Posted : 30/05/2014 6:03 am
Charge spoon / scoop / knife.. seem well liked.
I like em too.. spoon for mtb and knife for road / cx
Posted : 30/05/2014 6:04 am
There is/ was a saddle swap shop on yah bike radar forum, might be worth a go but I don't know how popular it is these days.
There's the specialized option, they'll measure you up in a concept store and tell you what should work.
Or just stick a charge spoon on.
I went for option 3 in the end, after trying a brooks for a bit.
Posted : 30/05/2014 6:06 am
 hora
I have a Spoon that I took off my mtb due to cockpinch'. Coult/would it be different on the road?
Conversely, i'm using a Kore T-rail saddle (and post obviously) on my road bike as it just 'works' for me. The saddle it came with was really painful so i took a punt on the Kore. Even though its a MTB saddle it works for some reason, maybe because its a race saddle?
Posted : 30/05/2014 6:19 am
Could/would it be different on the road?
It's your nether regions, so are you really going to listen to a bunch of opinions on here instead of getting your Allen keys out and trying for yourself?
I assume you've experimented with different angles and fore/aft positioning. If not, try it.
 beej
A decent LBS should have a bunch of test saddles for you to try - you get to borrow them for a few days. They might also be able to recommend ones based on shapes of others that are almost right.
Don't forget to buy the saddle you like from the LBS too.
Posted : 30/05/2014 6:21 am
I think it might be fashion but a lot seem to go for Fizik. I started with an Aliante which is their MAMIL's offering. Comfy for my arse (YMandarseMV). I have an Arione on my best bike as it's a bit lighter. A bit more hard core but ok for centuries and more for me.
Trouble is, 'what saddle?' is very subjective and you'll likely get as many options as responses.
Posted : 30/05/2014 6:33 am
 DT78
Can get expensive as the saddles aren't cheap.
I quite like fizik's way of describing who their saddles are for 'snake' 'bull' etc...cut out/no cut out. Then they started bringing out curved saddles and I'm confused.
I started out on an antares, tried a cutout flite and now on a tri version of the arione (it was cheaper...).
I think you just have to suck up buying / swapping till you find something that works and then stick with it / get a newer version.
On the mountain bike I've never had any issues with several different saddles I've tried.
Posted : 30/05/2014 7:16 am
 igm
Don't Fizik do a saddle testing thing?
Posted : 30/05/2014 7:22 am
This app should help you choose the right fitting saddle :
[url= http://flowmountainbike.com/post-all/innovation-saddle-selection-app-unveiled/ ]Saddle selection app unveiled[/url]
Posted : 30/05/2014 7:24 am
At the bottom?
Posted : 30/05/2014 7:26 am
Fizik does demo saddles if you can find a stockist, they'll lend you a (garish-coloured) saddle for a day so you can try it for real. They work really well on the road for me though of course ymmv. [[url= http://www.jejamescycles.co.uk/velozone/je-james-cycles-are-now-an-official-fizik-saddle-test-centre/ ]JE James for example[/url]] - or try borrowing a saddle or two from your mates.
The other thing that may make more difference on the road than on the mountain bike is a pair of shorts with a decent pad because you're not moving about on the bike on the same way as you would off road. I'm not saying you have to spend millions on Assos, I find the DHB Aeron Pro work really well for example, but it'll help.
Also, baggies aren't such a great call on the road for the same reason, they tend to have seams and folds in the wrong place. And make sure your seat height is right too, if it's too high you'll rock slightly from side to side and that's all kinds of bad.
Finally, as you ride for longer on the road, your butt will simply get a little more durable, though if your saddle is fundamentally uncomfortable that won't change.
Posted : 30/05/2014 7:30 am
I have a scoop on the winter roadie and it lovely on the old ass knuckles.
Posted : 30/05/2014 7:35 am
Don't forget to think about the pad in your shorts as well.Theres a big difference in comfort between the flat foam stuff and better quality shaped pads.
Posted : 30/05/2014 7:39 am
I had a revelation about saddles a few months back when I did a century on an 80 year old bike.
I always simply assumed that a certain level of discomfort was par for the course after 10 or so hours, you know mtfu, this is normal, need to ride more to harden up.
When I stepped of the old bike, it took me a while to realise a couple of things were missing. One was the sore arse, and the other was the lower back pain.
The first was because I was riding on its original sprung Brooks saddle, the second was because the bike was more upright than my usual.
When you consider that previous generations used to do big mileages as routine, maybe we should also consider maybe they knew a bit about setting a bike up for comfort. Almost all modern stuff is based around the racing perspective so that skews our thinking. A saddle is probably the last thing we should weight weenie on unless we are actually racing.
So now I have a shiny brand new Brooks saddle that weighs half a ton on my road bike and I'm thinking of getting another for my mtb. 🙂
(Should add I never wear padded shorts)
Posted : 30/05/2014 7:40 am
hora
I've Spoons on my three mtb but found it too wide in the centre for road. Different hip position and all that
Posted : 30/05/2014 7:44 am
Knife for the road.
Posted : 30/05/2014 7:45 am
@epicyclo yeah, but, but...
I had Brooks Pro on my tourer when I usually Use B17's. The Pro was purgatory for my arse and normality returned coincident with a B17. The Pro now lives in a plastic box marked 'folly'. I also bought a Day One and the generic Genesis saddle was a killer for me. An Aliante soon had my bottom smiling (and burping) again.
Trouble is, you simply can't put a 4lb saddle on a 16lb bike - it really is heresy.
Posted : 30/05/2014 7:55 am
I use Spoons and Specialized Toupes (143) for MTB. They are a similar width but are padded in different ways.
B17 on the tourer though - weight is less important.
Posted : 30/05/2014 7:56 am
I find I don't get on well with padding and seams/non slippy saddle coverings on a road bike.
Once rode a 45 miler on a stripped SLR with out even noticing!
Posted : 30/05/2014 8:01 am
From my experience (I'm really picky) the Selle Italia fitting 'system' is better than the spesh one. It measures two things, pelvic tilt as well as width.
The width is obviously how wide your sit bones are.
The tilt determines how much pressure is being pushed onto your notcher. It's dependant on the length of your hip flexors. So if you have an office job and correspondingly short hip flexors you rotate more so need a larger cut out in the saddle. Which goes some way to explain why for 200 years of the bikes history it didn't need a cut out in the saddle, but often does now.
The downside is I find the cut out can rub after a while.
Ebay's the best bet IME, stick to nearly new saddles that other people have tried and not liked, old saddles sag and get more or less (usualy less once the initial bedding in is done) comfortable over time. Doesnt matter so much if a £160 saddle doesnt fit if you onky paid £70 and can sell it for the same.
Posted : 30/05/2014 8:17 am
Have you tried altering your saddle position; height, fore and aft, tilt? I've recently converted back to drops on my road/commuter bike and the set up and position is a little bit different from my MTB. I am having success with a Brooks team pro after a ride to fiddle with my position. I did have a read of Sheldon Brown's page on eliminating bike pain as well first.
 hora
No lower back pain at all. Lucky there.
Posted : 30/05/2014 8:31 am
 scud
I can only recommend what i have, i'm a big unit at 16stone, but have a Fizik Aliante, has been by far the best and managed 250 miles in 24 hours on it.
Posted : 30/05/2014 8:46 am
Try the more padded Fizik'z (can't remember thier names) I can only suggest as I've always used Fizik'z because they suit my bottom shape well.
The slim versions for Race days are fine for a couple of hours hacking but if your bikes a bit stiff at the back end (never ridden your P-X)then the more padded saddles will help out.
New or S/H? good question, eBay will help you out, lot's of folks change saddles straight away on new bikes (like me) and end up with a few saddles kicking about, I eBay them stating they're new never used but came on a new bike, sold all so far, so a bit NOS really or BNWOT
Posted : 30/05/2014 8:48 am
boblo - Member
...Trouble is, you simply can't put a 4lb saddle on a 16lb bike - it really is heresy.
At any time in the last 40 odd years I would have thought the same.
Now my thinking is 16lb bike, 4lb saddle, WOW! a comfortable 20lb bike! 🙂
Here is my comfortable saddle in all its glory...
[url= https://farm8.staticflickr.com/7428/12913493594_13d35aa205_b.jp g" target="_blank">https://farm8.staticflickr.com/7428/12913493594_13d35aa205_b.jp g"/> [/img][/url]
The saddle is one of these and it's "only" 1,120gms 🙂
Posted : 30/05/2014 9:09 am
 hora
I have a Fizik Gobi currently on my mtb bike. Its there because my beloved WTB saddle literally fell apart. The Fizik causes numbness no matter how I position it.
would it be bad-form to fit a WTB? Then again what works on a mountain bike wouldn't translate to a road..
The one thing I do like about the Gobi is its narrowness to allow more movement in baggies.
Posted : 30/05/2014 9:14 am
baggies.
You'll never be comfortable, horrible flappy chaffing things.
Posted : 30/05/2014 9:17 am
hora - Member
...Then again what works on a mountain bike wouldn't translate to a road..
Very true, because what I use on my mtb is the polar opposite - an SDG I-Fly I-Beam - which is about as hard as it gets. I can happily ride that for 24 hours without discomfort, and again without padding. But that's because on a singlespeed I'm out of the saddle a lot. I can't go more than 3-4 hours on the road on it without starting to feel sore.
Posted : 30/05/2014 9:21 am
 hora
Could the Gobi work on the road bike? Will have a play.
Posted : 30/05/2014 9:32 am
molgrips has lots of saddles in his garage, go round and try some out 😀
http://singletrackworld.com/forum/topic/which-cheap-saddle-sdg-madison-flux-spoon
Posted : 30/05/2014 2:25 pm
In true 'recommend what you have' style a Specialized Toupe+ works for me, though I've not ridden it more than 7 hours. Charge Spoon was horrid.
Have a Planet X team saddle on another bike and that is ok for 50 miles.
If you take the Specialized sit bone/saddle recommender I would almost put money on you needing a 143mm saddle.
I tried the snappily named selle italia max flite gel flow and didn't really like it, just haven't got around to selling it, because you never know...
Posted : 30/05/2014 4:47 pm
 SamB
I went with the Fizik demo program, which worked out nicely. Got to try two saddles for a fortnight each, then picked the one that felt nicest. However, I did have to pay retail for the saddle. IMO it's worth it for a comfy bottom on long rides.
Posted : 30/05/2014 4:56 pm
Give the Spoon a try. It's a favourite amongst Audaxers, right behind Brooks, so it can't be that bad.
I've used one on and off for about three years, swapped around 3 different bikes, and whilst at times I've cursed it, I'm currently getting on with it very well, riding anything up to 10 hours on the road bike. Position is very important with it, I've found. There's little margin for error. I'm still certain there's a comfier saddle out there for me somewhere, but for now, the Spoon is satisfactory.
Posted : 30/05/2014 5:07 pm
hora - Member
Only thing will be position, you will sit differently on your roadie and the wtb maybe made for an upright position.
Only thing to do is try it, bet it gives you numb balls..
Posted : 30/05/2014 5:33 pm
From memory the Gobi and WTB saddles are completely different shapes,Gobi's have more of a rounded top whereas the WTB's normally have 2 raised sections to the rear not unlike a Charge Sppon.
My arse suits saddles with a more rounded top, currently using a Turbo on the road bike and a Concor lite(for extra liteness) on my rigid MTB, both have similar rounded tops,got a spoon on the Hardtail which is Ok for rides upto 1hour but then discomfort sets in.
Sounds like you need something more like the WTB's if that was previously comfortable on the mtb.
Posted : 30/05/2014 6:21 pm
B17. Can ride one in jeans with absolute comfort.
For something lighter test a Fizik Aliante.
My favourite is a Flite Ti original, but I am happy on an Arione as well. The testing is helpful, but different saddle coverings have different feel. The smooth white/black Arione on the commuter is much firmer than my other two.
Posted : 30/05/2014 8:03 pm
 hora
So..I took the chunky WTB idea and ordered...a slightly slimmer WTB Silverado at 14quid sale. Bikeradar hated it, mtbr reviewers are good.
But then when did UK mags like WTB aka non-mag advertising company..
Posted : 30/05/2014 8:19 pm
 hora
I fitted my old Charge spoon. I didn't even notice it. Weird. I hated that on the mountain bike. Tonight I'm experimenting with the new WTB- if I don't get on with it, I'll order a new (not tatty) Charge Spoon in black for the road bike 🙂
Posted : 05/06/2014 6:29 am
Get some proper shorts and a decent road saddle. (Specialized/ San-marco/fizik/pro-logo/selle italia etc).
Posted : 05/06/2014 7:54 am
 hora
No. I've found that I like my padded inner lycra under green cargo shorts. It doesn't flap etc either. Sorry if its not 'road' and its probably abit american or amateur but I think grown men in lycra shorts should either be elite/top club riders/pro's.
Anyone else- it looks creepy as ****.
Posted : 05/06/2014 8:08 am
It's a strong look
Posted : 05/06/2014 8:13 am
I think grown men in lycra shorts should either be elite/top club riders/pro's or teens.
You will understand once you have done some proper cycling 🙄
Posted : 05/06/2014 8:15 am
hora - Member
tempt sir with a charge scoop? - much like the spoon, only a bit lighter, and no seams.
I think if you only got sit bone ache, then you were on your way to a winner anyway - that's where you should be supported, and often if you're not used to the time in saddle (and on road it's lots of time in saddle vs off road!) or position on bike etc. then you're bound to get some achy arse. It's when you get numbness, ass chafing, sores etc. that you know you've got the wrong saddle.
The ideal I've found is something that noticeably supports sit bones without relying on too much soft tissue to support around that area, which of course varies massively between individuals.
Reminds me of the time a Rolls literally made my arse bleed after three weeks use on tour.
Posted : 05/06/2014 8:17 am
 hora
Scoop it is.
I'm going to do 3x40miles a week on the road. I don't think thats bad.
Posted : 05/06/2014 8:29 am
Get your sit bones measured. You need three things:
a) To know what width you need
b) To know how your hips rest which is affected by the shape of the saddle across its width, its profile.
c)To know according to posture how you perineum sits on the saddle.
I had the same issue as you, cured by moving from a 135mm width to 145mm and a flat profile.
cloudnine - Member
Is anyone riding frequently able to comment on whether the stitching has had an adverse effect on their lycra?
[quote=hora ]No. I've found that I like my padded inner lycra under green cargo shorts. It doesn't flap etc either. Sorry if its not 'road' and its probably abit american or amateur but I think grown men in lycra shorts should either be elite/top club riders/pro's.
Well you're the one complaining about being uncomfortable 🙄
Posted : 05/06/2014 8:33 am
Yeah, what aracer said. I'm expecting a "What medical treatment for open sores" thread soon. The quicker you realise that lycra is more comfortable on road bikes the quicker you won;t be wondering why your groin feels like someone went at it with sandpaper or, like the last time I rode to work in jeans the long way around, how someone seems to have kicked you repeatedly in the balls without you noticing.
It's all about the best equipment for the job really.
Posted : 05/06/2014 9:04 am
No problems from mine on my mtb.
Posted : 05/06/2014 9:07 am
Oh and I use Selle Italia SLR on both my road bikes. They work really well for me but aren't super cheap
Posted : 05/06/2014 9:08 am
I have Spoons on all my bikes. There's a small amount of bobbling on the inside thigh area of my bibs, but that's over a few thousand km. Given how comfortable I find the saddle I'm quite happy to take a slightly reduced lifespan of my shorts.
Posted : 05/06/2014 9:14 am
Ref the Lycra thing. Tried it, no more comfort than baggies, with the added advantage of not looking like a sex pest at work.
Heaven forbid, I'm even going to start doing the commute one day a week to my other office which is a 120km round trip, all in baggies, with a helmet that's got a peak, and a rucksack 🙂
Posted : 05/06/2014 9:17 am
 hora
Sorted though.
I just can't face 'just' lycra on its own. I like to wear clothes not look line Basildon's alternative Super hero to Batman.
I wont be doing centuries on the bike. Its for getting out after or before work.
Weekends are for off road.
Posted : 05/06/2014 9:20 am
Went from a san marco regal-e (which was nice but has limited padded
zones) to a prologo scratch .... sweeeeet 🙂
I've just swapped out 2 Specialized Phenom's from my MTB's and a Romin pro from my road bike and put £20.00 spoons on all 3. Road one is taking a bit of tweeking but not having the probs I had with others after 3+ hours. Decent padding in shorts makes a lot of difference.
Posted : 05/06/2014 9:33 am
[quote=hora ]I just can't face 'just' lycra on its own. I like to wear clothes not look line Basildon's alternative Super hero to Batman.
I think you need to face the fact that most people think you look silly on a road bike whatever you wear, and those who don't will think you look more silly with your clothing choice. Up to you though if you want to look more silly and be more uncomfortable.
Posted : 05/06/2014 9:50 am
 hora
It is comfy though. If I felt uncomfortable I'd switch.
Mountain biking- I just can't wear padded shorts no matter what.
Posted : 05/06/2014 9:53 am
Ah, so clearly you're right and thousands of roadies are wrong then.
Posted : 05/06/2014 9:56 am
 hora
I'm not a roadie. I'm using a road bike to train on. I've no interest in 'crits, road gangs, Sportifs etc etc. I don't want to develop arms like a Tyrannosaurus Rex, I don't want to plaster myself in a manufacturers logos to pretend I'm a pro-rider, nor do I want to wear a cycling amateur club tshirt and ride with 10 other same-shirted club members trying to beast ourselves/forget about a marriage gone stale. I don't want to worry over stats, obsess with detail, worry about Strava-esque type problems.
I'll do my ride, enjoy it and hang the bike up afterwards and smile/relax.
I've said it before, road is my dirty hotel mistress where you shoot and leave, mountain bike is my beloved wife who I love.
Ride, shoot the breeze, go home.
:mrgreen:
Posted : 05/06/2014 9:59 am
To be honest, in my experience (baggies for touring etc. in spite of only wearing lycra on the road bike), baggies can be worn quite comfortably as long as there's no seams that end up between the sadddle/arse interface. Seriously, if someone wants to look a bit more normal on a bike, it can be done without any major impact on comfort - aching sit bones as per the OP will NOT be due to wearing baggies, they're far more likely to cause saddle sores.
Posted : 05/06/2014 10:05 am
This.
The Consultant Urologist who carried out my op told me the proportion of men he was treating that cycled regularly had increased markedly in the last 5 years. You may or may not be doing damage down there but, if you are, it is a gradual process which can have some very nasty end results. He was actually in the process of writing a paper on the subject at the time.
The answer is a saddle that fits you - not one that's comfy/a favourite amongst the masses/a bargain.
Posted : 05/06/2014 10:06 am
 hora
Nobby on the mountain bike over the past few months I've had bell end numbness, etc since I've gone from my WTB rocket V (that had to be binned as it fell apart) and onto what I could find in the spares box. Did worry me alittle what it must be doing to nerves etc down there longterm.
(BTW I don't wear cargo pants off road) - the pants stay, I'll investigate a decent fitting here in Manchester for offroad and on road saddles.
Posted : 05/06/2014 10:10 am
Kryton57 - Member
i've got a spoon on my commuter, it's eaten 2 pairs of shorts in 2 years, i ride about 100km/week, the saddle is starting to look a bit shabby.
i'd change it, but:
1) my bum really likes the shape.
2) i'm kind of curious to see how this saddle vs shorts battle plays out...
Posted : 05/06/2014 10:15 am
I had my sit bones measured, and the result was the most uncomfortable saddle I have ever used.
Posted : 05/06/2014 10:19 am
...Yet.
Posted : 05/06/2014 10:21 am
 hora
Yet?
Everyone likes nailing someone from the office? 😆
Posted : 05/06/2014 10:23 am
 scud
As above, give a Fizik Aliante a try, i was always a mountain biker and i could not get on with Charge Spoon on either MTB or road bike, the Aliante was recommended to be by bike fitter and it has been great, never had any issues at all when coupled with decent shorts.
Posted : 05/06/2014 10:42 am
+1
If this is a new saddle, it could well be the first time you have actually sat on your Ischial Tuberosities properly. It is completely normal to find this uncomfortable, for a while. If it doesn't improve for a couple of months, then pop to your local spesh dealer and get yourself a saddle with some science behind it.
Posted : 05/06/2014 10:49 am
How does that work then? I think people in Lycra look silly.
Posted : 05/06/2014 10:50 am
Quite like that monologue earlier hora..
Posted : 05/06/2014 11:31 am
 hora
Why do people get into a sport and think they must progress along a 'career hobby' conveyor belt as defined by their peers?
"Nice bike, are you planning any Sportives this year"
- No I'm going to ride and enjoy my bike thanks.
I don't care if I'm 10th on a particular stretch of trail against 200 total strangers. Who gives a **** about Strava, wheelsizes (what we 'should' be riding now) or what I should be wearing? Is it a conformist uniform.
Posted : 05/06/2014 11:49 am
You're asking about comfort. people as saying that Lycra without baggies is more comfortable.
Posted : 05/06/2014 11:54 am
 hora
Its not snagging and its not flapping though.
Its the sitbones I asked about in my OP. Sitbone comfort isnt improved by taking away a thin layer of fabric from the equation.
Posted : 05/06/2014 11:56 am
Yes but it's you so all bets are off.
Anyway, to add to the consensus, it sounds like you've probably actually found a good saddle but aren't yet used to sitting in the right way (eg sit bones). Give it a few rides.
Posted : 05/06/2014 11:58 am
 hora
I'll pick up a secondhand scoop too when one pops up.
Posted : 05/06/2014 12:02 pm
...says the man with a long list of past equipment that closely resembles the en-vogue STW guidline du jour...
Posted : 05/06/2014 12:09 pm
 hora
Are you calling me a fashion cyclist(TM)? 😯
Posted : 05/06/2014 12:18 pm
