Road racers - tyre ...
[Closed] Road racers - tyre pressures?
[#5188468]
Chatting to another rider at the end of of club ride today and he commented that racers reckon a lot of amateurs put too much pressure in their tyres.
I run Rubino Pro which will take a massive 145psi but run them 120-125. It's a carbon frame and fork so this isn't uncomfortable and I get no punctures, which is nice.
But are there any disadvantages to this? Smaller contact patch = less grip for e.g?
This isn't for racing, just wondering if racers have better insight into what's best
Posted : 25/05/2013 3:16 pm
Lots of recent research indicates that pressures of 120psi and above are pretty much counter-productive. I did find a weight/pressure chart somewhere suggesting that nearer 100psi was good for me.
Edit here's one http://www.vittoria.com/tech/recom-tyre-pressure/
Posted : 25/05/2013 3:17 pm
 aP
80-85 front, 90-95 rear.
Posted : 25/05/2013 3:18 pm
I'm under 100 - tyres are 25s though, if that matters
Posted : 25/05/2013 3:24 pm
i run 95-100, its a nice balance between progress and comfort on the shoddy south gloucester roads....
Posted : 25/05/2013 3:35 pm
95 - 105. I find too high and it can 'bounce and judder' when cornering hard.
Posted : 25/05/2013 3:44 pm
 aa
110psi. It does feel firm.
Posted : 25/05/2013 3:58 pm
I remember reading Ian Cammish puts no more than 115 psi in his tubs. The general feeling is that any higher and they 'bounce' rather than roll.
Saying that I have a mate who regularly puts 145 psi into his clinchers. 😯
Posted : 25/05/2013 4:02 pm
What was the question again?
Posted : 25/05/2013 4:44 pm
 mrmo
i have run 145psi in my tyres on occasion, if you can find a smooth stretch of tarmac you really do fly, but how often do you find smooth tarmac? Usually i pump the tyres upto 110, then top them up a few weeks later when they feel soft/draggy.
Posted : 25/05/2013 4:49 pm
I still let mine down after a ride, dunno why always have.
Posted : 25/05/2013 5:03 pm
The idea is to get a certain %ge of "Sag" in your tyres, I cant remember what the actual figure is. So no use really except to say it will depend on the type/size of tyre and you + the bikes weight. Me being heavy I worked it out to 110 psi rear and 100 psi front for 23c Michelins
Posted : 25/05/2013 5:15 pm
i weigh 12stone anderbit, in my 25mm tyres i run 80front, 90 rear. any more and my teeth get shaken out, any less and i feel a bit close to dinging potholes.
(we have fields of potholes that stretch as far as the eye can see, it's not as if i can just avoid them)
i suppose higher pressures might roll a bit easier, but i doubt i'd be tearing strava to shreds if a whacked 'em up to 120..
Posted : 25/05/2013 5:21 pm
About 100ish. Never more than that alhtough the tyres I've got are rated to 130psi. For my weight and the tyres I've got on I find it's the best combination of grip, comfort and puncture resistance.
On the track I run about 120psi.
Posted : 25/05/2013 5:28 pm
I run 23c's at 105 on the front and 110/115 on the rear. If its wet ill drop 10psi but normally I just ride out on that.
GP4's BTW.
Posted : 25/05/2013 5:32 pm
85 front, 90 rear
running 25mm tubeless.
Posted : 25/05/2013 6:28 pm
90 front and 95 rear in 25c Vittorias. Put them up a bit when we race on the motor circuit as it's beautifully smooth tarmac.
Posted : 25/05/2013 6:57 pm
23 Conti 4000s - 110 psi
20 Veloflex Masters - 100 psi.
Posted : 25/05/2013 8:00 pm
Why would you run lower pressure in smaller tyres?
Posted : 25/05/2013 8:10 pm
I was running 100-110 in my 23c gatorskins on the old bike. The new bike has yksion pro's on R-Sys wheels and I nearly died on the first ride with max pressure! On monday I ran 120 and the thing was unbearable on a rough stretch of road. I'm about 12 1/2 stone and found 110-115 fine on sundays long ride.
Posted : 25/05/2013 8:13 pm
