So watching the sufferfest vids I realised how flat backed and low the pros ride on the bike. Now I know I'm not and never will be a pro but I measured my drop, and it is only 6cm from saddle tip to hoods. If I try to go and lower than that I actually knee myself in the chest at the top of the pedal stroke and restrict my breathing. Raising my saddle means I am start rocking at high cadence.
So how do these guys ride like that? I am flexible, can easily put back of palms on the floor/head on knees without any trouble.
Yeh, I get that tooI actually knee myself in the [b]"chest"[/b]
ride a proper bike with proper handlebars and your calamity will disappear. ๐
20 mins till I finish work.
restricted breathing sounds like you're back is bent.
6 hours ago I finished work
Sports bra for the moobs? ๐
does you bike have a high BB (crosser maybe ?)
Why would a high bottom bracket make it more difficult to achieve a position with a large drop to the bars?
Lol not a fatty so no moobs! Its a rose pro rs dont think it has a particularly high bb but im no expert.
When you say back bent i was thinking a curve in the back might actually give more breathing space
I suppose I was imagining a high BB with a low front, so knees closer to chest, but I guess that'd be unlikely in a sensible frame. My problem's belly, not chest, so it's my thighs that catch and the only solution I can see would be 125mm cranks ๐ณWhy would a high bottom bracket make it more difficult to achieve a position with a large drop to the bars?
Move the saddle forward, or get a bit further forward on the saddle. When you see the pros with elbows dropped, they're usually perched right on the tip of the saddle which opens up the angle at the hips. Same reason that TT bikes typically have a very steep seat tube.
Yeah, the reason you're kneeing yourself in the chest is because you can't achieve the pelvic tilt that the pros can when they run lots of bar drop. That mostly due to flexibility.
Although most people who can put their hands flat on the floor can tolerate more than 6cm of drop. 6cm is by no means a small amount, but it's definitely not loads - unless you're really short, then it could be quite a lot. However you may have long arms or poor glute flexibility (or both), thus meaning the greater drop doesn't work for you.
You shouldn't have to slam your saddle forwards to achieve the position, that's usually something you do when you're running too much drop for your glute flexibility.
That's me in the kind of position you're suggesting, knee is a few mm behind the pedal axle.
Thanks for putting that vid up, I think you are right, when I lean forwards and go lower on the hoods / drops I kind of fold in half rather than have a curved spin like you do in that vid (if that makes sense). So my pelvis rotates towards the top tube whereas yours pelvis looks more upright with the spine curving to make the drop, and therefore your chest is higher up than mine.
What sort of stretches or exercise help with improving flexibility in the pelvis?
Obviously you can't stretch a bone ๐ However, you primarily aim to stretch the glutes, adductors, lower back and hamstrings. Foam rollers and google are your friends!
