Road levers that wo...
Road levers that work with Shimano SLX 11 speed derailleur and cassette
[#13168121]
Has anybody made this work? There's an article on Bikepacking saying it can be done with a Shimano 105 and a Wolf Tooth Tanpan. Has anyone tried this? I'll be using an SLX 11-46t cassette instead of the SunRace one in the article, I'm guessing that will be ok?
https://bikepacking.com/gear/guide-to-mullet-drivetrains/#V
Posted : 25/02/2024 1:49 pm
Interesting, I’m trying a 10 speed big mtb cassette with ultegra shifters and rear mech.
Seems fine except chain too short. I have a mech extender ready. Need to have a proper play.
Posted : 25/02/2024 1:56 pm
11s tanpan does what it says on the tin, been using one since 2016 or thereabouts
Posted : 25/02/2024 2:04 pm
"11s tanpan does what it says on the tin, been using one since 2016 or thereabouts"
This sounds good
Posted : 25/02/2024 2:25 pm
Same here, ran 105 levers I think with slx 11-42 via a tanpan. I think I sold the tanpan but do still have the levers and flat mount brakes if you're interested. Left lever is converted for dropper post though.
Posted : 25/02/2024 7:04 pm
Cable or hydraulic brakes?
Posted : 25/02/2024 7:10 pm
Cable
Posted : 25/02/2024 7:21 pm
Will double check what model numbers they later, but hydraulic, RS505 rings a bell, 11spd, front and rear with mounts, 160mm CL rotors and 27.5x125mm KS internal dropper if required.
IMG_20220213_165331IMG_20220213_165048
Posted : 25/02/2024 7:22 pm
Not really answering your question but a grx 812 rear derailleur manages 46t no issues. YouTube suggests it'll do a 51t cassette aswell.
Posted : 25/02/2024 7:59 pm
Yeah, GRX rear mech might be you buddy here
Posted : 25/02/2024 10:19 pm
I'm using these:
https://www.microshift.com/models/sb-m110/
Posted : 25/02/2024 10:31 pm
"I’m using these:
Drop Bar Shifters for Shimano DynaSys 11"
These look good! Which type of brake caliper are they compatible with? I have road (short pull) mechanical ones
Posted : 25/02/2024 10:54 pm
Road - working well with BB7 road disk. Shifter paddles operate differently to Shimano, takes a couple of rides to get used to. Working fine with an 11-46 MX8 cassette and 12 speed Deore mech.
Posted : 25/02/2024 11:11 pm
Microshift XLE 110 are designed to be compatible with 11 speed MTB rear mechs.
Posted : 25/02/2024 11:14 pm
"montgomery
Road – working well with BB7 road disk"
Perfect, thanks for that! I've bought a pair. Currently going for £99 at Chicken Bike Kit on ebay if anyone's interested!
Posted : 26/02/2024 11:54 am
That's a fair price, RRP was/is a bit steep. I like the fact the gear cable exits externally, not under the tape - loads of room behind it for a bar bag, and the integrated barrel adjuster means you don't have to split the cable elsewhere to put in a tension adjuster. Easier to change cables, too. My old Sora levers were like that.
I think Microshift should've made a version compatible with long pull brakes, though, as I suspect some people (me!) would've liked to use them with old MTB kit out of the spares box.
Posted : 26/02/2024 12:52 pm
"I think Microshift should’ve made a version compatible with long pull brakes, though, as I suspect some people (me!) would’ve liked to use them with old MTB kit out of the spares box"
That was my original set up, I would have snapped them up too. I went with Gevenalle in the end, which have been ok but I haven't loved them so I'm gonna sell them.
Posted : 26/02/2024 2:06 pm
