Road fork recommend...
[Closed] Road fork recommendation
4 Users
Hi,
I'm looking for a fork to the following specs
Carbon
Rim brake
375mm axle to crown
45mm rake
lower bearing 1.5inch
I don't really understand the impact on different mesasureents on the the ride - i.e. if I wnt for a fork with a slightly high axle to crown what does that mean? I can't find a fork to these specifications but have found some similar.
Thanks!
Matt
Posted : 27/01/2020 7:51 pm
Longer fork will raise bottom bracket, slacken off head and seat angle, lengthen wheelbase and decrease reach. Bike will probably feel a bit less racey and a bit more relaxed although by how much depends on how much longer fork is.
Posted : 27/01/2020 8:07 pm
Thanks. I've found a fork that is 367mm (8mm shorter) and 46mm rake (+1mm) more. So it lowers bottom bracket but would the increase in rake be enough to offset the reduction in fork length and keep a similar ride?
This is a "3T fork Ragida Team Stealth". THe bike is a Bowman Palace R, original fork has been cut too short for me.
Matt
Posted : 27/01/2020 8:26 pm
Have you tried contacting Bowman to see if they can sell you one?
Posted : 27/01/2020 8:50 pm
Yeah a few times over the last 9 months. They say they'll get back to me but never do, I even asked for a scratched one.
I like Bowman but as they are quite small parts like this are hard to source. They used to have forks listed on their website but these have disappeared.
Posted : 27/01/2020 9:43 pm
You are overthinking this, you will not notice any difference in the ride of any road fork, 8mm is 0.5 degrees.
Posted : 27/01/2020 9:45 pm
Ahh cheers cynic-al - that is what I needed to hear. Getting it bought.
Posted : 27/01/2020 9:52 pm
