Road Carbon wheels ...
Road Carbon wheels - think I'm losing my sanity
So is it less of a concern to ride your "best" Carbon road disc brake wheels in the winter than it is with a rim brake?
I'm guessing its only water and dirt ingress into the hub bearings to worry about... right?
Posted : 23/12/2022 9:33 am
You've still got all of the salt on the road to corrode your nipples and potholes filled with water to smash the rims.
Posted : 23/12/2022 9:35 am
Yea but you'll be going faster so less time on the road = less chance of damage.
#gofastorgohome
Posted : 23/12/2022 9:40 am
I don’t own any non carbon road or gravel wheels anymore as I have discs on everything. Having said that my ‘rough’ wheels are still Hope RS hubs on LB rims, I did build them with brass nipples though. I wouldn’t run calliper carbon rims in winter filth.
Salt eating the nipples and damaging the hub finish is more of a concern than water/dirt ingress in the bearings.
Posted : 23/12/2022 9:43 am
Ok thanks, so I'm not going mad. Seems a pair of sales wheels / Hunt all seasons rinsed off after a winter ride is the order of the day.
Posted : 23/12/2022 9:47 am
I run my road bike all year. It is a carbon frame that can take full length mud guards, SRAM force/red mix groupset and Roval CLX 50 carbon wheels.
I just keep an eye on the nipples for corrosion. If they start to go, I'll change to brass nipples.
Posted : 23/12/2022 9:51 am
Front wheel installed on the turbo for the aero gains. 😉
Posted : 23/12/2022 9:58 am
So is it less of a concern to ride your “best” Carbon road disc brake wheels in the winter than it is with a rim brake?
I’m guessing its only water and dirt ingress into the hub bearings to worry about… right?
Just clean & dry them after every ride, another thing I've done is apply ceramic coating spray to the rims, they stay rather clean.
Posted : 23/12/2022 10:05 am
I don't do enough winter road riding to bother with a winter bike or wheels any more, but I'd probably get a set if I did.
If only to have the slightly tougher tyres set up on.
Posted : 23/12/2022 10:07 am
 Haze
Grit and salt in derailleur bits and bottom bracket…maybe not a big deal for some but it’s something I’d rather avoid as I have an older bike to run through the shitter months…even if it does have eTap and rim brakes!
Posted : 23/12/2022 10:26 am
I run my best bike a wheels all year. Granted they are not mega money but probably many many times what the average normal person would consider paying for a bike (base spec Tarmac and some recently acquired black Friday VEL carbons wheels from Sigma). As Chakaping said, I don't do enough miles in either season to warrant specific bikes and I'd rather enjoy it and wear it out than save it for best and never ride it
Posted : 23/12/2022 10:41 am
Wait, Shimano 12sp cassette's fit an 11sp hub don't they?
Posted : 23/12/2022 11:05 am
Wait, Shimano 12sp cassette’s fit an 11sp hub don’t they?
Yup
Posted : 23/12/2022 11:27 am
I don't ride my road bikes in winter as they can't take mudguards and I can't be fagged messing about with Raceblades and suchlike.
I don't have carbon wheels on my other bikes and ride a lot of miles. Keeping up with wheel and BB bearing changes/maintenance is (almost) a full time job.
Posted : 23/12/2022 12:04 pm
another thing I’ve done is apply ceramic coating spray to the rims, they stay rather clean.
I use Finish Line Protectant Wax/Polish, does the same job. Works really well, water just beads off the rim and a quick wipe down after a ride is all that's needed.
Posted : 23/12/2022 12:06 pm
Winter bike for winter riding, without the carbon wheels. That’s dry summer. And no I do not run discs. I also don’t run a derailleur in winter either.
You can of course rinse off the bike after every ride.
Posted : 23/12/2022 12:09 pm
Yeah I was googling.... in which case the DT Gravel wheels I just put in the classified will suit the purpose, I'd better withdraw them!
Thanks Steve_b77/ UK
Posted : 23/12/2022 12:15 pm
