Road bike brake pad...
[Closed] Road bike brake pads - will these fit?
No experience of buying road bike brake pads, i have bog basic tektro cantis that need new pads. Will these fit and are they any good?
http://www.chainreactioncycles.com/Models.aspx?ModelID=27240
Posted : 10/06/2012 3:34 pm
If you have a road bike, are you sure you have canti brakes, not caliper (single or dual pivot) brakes?
If you have Cantis, with out knowing the mount type you have, threaded, non threaded etc, impossible to answer.
If you have a road bike with normal road brakes, they will fit, as they are a complete pad & shoe unit, but given that they are a very old design / spec, and have plastic (integrated) holders, don't expect great braking.
If your on a budget, [url= http://www.wiggle.co.uk/ashima-one-piece-black-brake-blocks/ ]these[/url] have good reviews, if you can stretch a bit, would look at getting a brake pad with a seperate shoe, so you can swap the pads only, which will work out cheaper in the long run, CRC has 6700 pads / shoes [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=61807 ]here[/url] which are nice
Posted : 10/06/2012 3:52 pm
Threaded post type pads - similar to these brakes [img] [/img]
Posted : 10/06/2012 5:41 pm
