Road bike brake blo...
[Closed] Road bike brake blocks ?
Need to replace the brake blocks on my road bike.
Any recommendations on stuff that won't break the bank.
Posted : 22/09/2017 2:24 pm
....how quaint... ๐Ÿ™‚
Posted : 22/09/2017 2:25 pm
Depends on the braking surface, are the wheels anything out of the ordinary?
Posted : 22/09/2017 2:33 pm
Go to [url= http://www.wiggle.co.uk/cycle/rim-brake-pads/?o=2 ]Wiggle[/url] choose some that will fit and are in your price range.
Does it get used much in the wet ?
Posted : 22/09/2017 2:34 pm
Always hear Swiss stop are good. The brakes on my road bike are fine in the dry, but awful in the wet. Cheap Tektro things, but I think they have Shimano brake pads in at the moment.
I'm switching to some Sram Apex brake caliper with Swiss stop pads in (that I got a bargain on from eBay) when I get time to fit the things.
Posted : 22/09/2017 2:36 pm
I have a single set of unused BBB Roadstop Deluxe that are surplus to requirements since I no longer have a road bike with rim brakes.
No complaints about them in use - enough stopping power for descents in the Dolomites.
Let me know your address and I'll send them out to you.
Bank - unbroken.
Posted : 22/09/2017 2:40 pm
BBB Roadstop Deluxe
OP, this would be a win - I put some of these on my bike recently and they were a massive improvement over the original pads.
Posted : 22/09/2017 2:48 pm
Thanks all.
StefMcDef you have pm
Posted : 22/09/2017 2:51 pm
Get the Wiggle lifeline ones. I find both for Alu ans Carbon rims most excellent in all conditions for a fraction of the price.
Rumor is rhe Carbon ones are actually Reynols Blue pads.
Posted : 22/09/2017 2:53 pm
Dura-Ace are lovely on alu rims, having played with lots of other options I keep coming back to them.
Posted : 22/09/2017 2:54 pm
 cp
I bought some SH brakes which had green Swisstop in - swapped the pads onto my summer road bike and noticeably better performance and feel compared to standard Shimano inserts.
Posted : 22/09/2017 2:56 pm
this made me remember something I thought about while riding my road bike yesterday. I've never changed the brake pads on it. i've had it maybe 6 years, done probably 10,000 miles on it. Brake pads are barely worn.
Posted : 22/09/2017 3:06 pm
Stock ultegra and dura ace pads are great.
Swissstop marginally better, but probably not worth the extra cost.
Swiss Stop Blue here.
Posted : 22/09/2017 3:11 pm
Used to get mine from discobrakes. You know, like, back in the day.
Get mine from Fibrax. Make sure you get cartridge pads if you've not already got them!
Posted : 22/09/2017 3:16 pm
If it's for winter use, then Kool Stop Dura Ace (salmon colour) are the best imho. They don't last as long as Swiss Stop Green, but the performance is better. FWIW I also recommend the Kool Stop thinline for CX cantilevers.
Posted : 22/09/2017 3:17 pm
renton - Member
Thanks all.
Gotcha! Should be on their way today.
When I say "single set" I mean, there's only one pair of brake blocks, not two pairs, but they should be more use to you than they are to me.
Posted : 22/09/2017 3:35 pm
Stef
That's absolutely fine mate. I really appreciate the gesture.
Thinking about it I don't think I've ever changed a set of road bike blocks.
Posted : 22/09/2017 3:44 pm
Swissstop blue here too.
Betterer than 6800 Ultegra standards in the wet by a margin
Posted : 22/09/2017 4:04 pm
I found ultegra 6800 okay in the wet, but noticed I'd worn the rim passed the wear indicator in just 2 long very wet rides.
Lifeline in st the moment, but I thought I'd use something fancy for the winter.
What are the SS blue like at rim wear?
Posted : 22/09/2017 4:30 pm
Stef
They're on their way, mate. These ones were way better than the stock Campag ones they replaced. If I could set 'em up properly, they must be well designed. They have a wee sort of ball-socket thing in the back of the blocks that makes it easy to fine-tune the angle of them against the rim.
Posted : 22/09/2017 5:51 pm
Changed the standard pads on my shimano 105 brakes to swissstop and the difference is night and day. Green swisstop, wheels are campagnolo neutrons, great upgrade
Posted : 22/09/2017 11:11 pm
Whatever pads you fit, they will work better if you clean them and the rims after a wet mucky ride and pick out the shiny bits of alloy and grit.
Posted : 23/09/2017 7:02 am
