I have noticed that when I have the bolt done up tight enough to stop the post slipping (which is pretty tight), the bolt has quite a bend, with both ends pointing forward a few degrees as the steel frame lugs are pushed in under tension. Any likliehood of the bolt breaking ? think i might get a spare one.....
(newish Thomson post, dry and clean, no wear and a tightish fit to push into frame)
Thanks
just seen a pic on another thread where someone has put a QR clamp on - looks like a salsa maybe ? might try that if someone could advise size etc and how it works with the lugs
[url] http://www.singletrackworld.com/forum/topic/rock-lobster-853-riders [/url]
Hmmm, I used to have an RL so understand what you are saying. I definitely got a replacement bolt from Merlin, used a Thomson seatpost too. Must confess to being rather paranoid about slipping seatposts!
PeterPoddy may be able to help as Mrs Poddy had one too.
cg - thanks for that, think I'll order a spare bolt for bottom of my camelback !
yeah, I reckon PP will have an idea -) I sold him my first RL853 frame which he singlespeeded after I damaged the mech hanger dropout !
now where is peterpoddy when you need him ? ๐
iainc - my (bought in '09) RL853 came with a 'normal' seat tube so that I used a 'normal' QR collar, much like the one in the photo, I suspect.
JonT - mine is an 06, and has a couple of lugs brazed on the tube which take a bespoke bolt - sounds like they have updated, cheers
I'm on holiday when you need me! ๐
Actually I never had a problem with the normal bolt. Kirsty had a Lobster too, and we dud fit a QR to that for a while, but it was only cheap and never worked too well. I reckon your best bet us to make sure you have a decent seatpost ( that's not worn in the clamping area) and get either a new bolt from Merlin, or a really good quality replacement from somewhere else: I.e. Not a bike shop!
cheers Peter - the Merlin bolt that is in is ok, it just takes a bit of a bent banana shape when tightened up enough (good Thomson post, not worn, tight fit, 12.5 st rider ๐ There is actually no way the bolt cannot bend, as the faces on the lugs lean in towards each other at the front when tightened. I think the lugs have maybe stretched a bit over time. I guess as long as the bolt holds the post it will be okay, as it is made of steel - just a bit worried about eccentric loading on the threads. I think I will just get a spare incase and then forget about it !
