Riser Bar - how wil...
[Closed] Riser Bar - how will it affect handling of my hardtail (versus a flat bar)?
[#3836575]
I have a 685 mm flat bar (Easton EA30) on my xc hardtail (Decathon 8.2, 115 mm fork). I have found my small nads do not give me the confidence needed approaching drops and steep terrain.
Would a riser bar (of similar width and sweep) make the bike feel more relaxed and allow me to feel more confident? I am thinking that the position may allow me to be slightly less 'leant forward'.
I have a 100 mm stem, with 10 degree rise (if that makes and difference). Is it the bar I need to change (rather than the stem)?
Posted : 03/04/2012 10:49 pm
 mboy
If you put a bar with a slight rise on it, you will raise your front slightly and shift your weight bias back on the bike slightly.
Similar thing happens if you fit a shorter stem.
Posted : 03/04/2012 10:51 pm
You need mahoosive wide bars, a 50mm stem and before you know it you'll be riding like Steve Peat. Just don't go near any trees 🙂
Posted : 03/04/2012 10:55 pm
You could go for a riser or a shorter stem or both. Either could push your weight back and lift your head a touch. If you find the bar comfy you could try a cheapo stem to see if you like it and then buy a decent one ifyou do and its easier to swap stems than bars.
Would try around the 70-80mm mark.
Posted : 03/04/2012 11:18 pm
