Rim tape necessary ...
[Closed] Rim tape necessary or better substitutes?
[#3928974]
Do I really need rim tape or am I better off just getting electrical tape and giving it a generous wrap-a-round?
Posted : 30/04/2012 7:04 pm
I have used electrical tape and its been fine but i guess it depends on how sharp the edges of your rim are/how thick you wrap it/tyre pressure.
Posted : 30/04/2012 7:06 pm
Elec tape seems to work ok at mtb pressures but for the £3 I'd get the real deal.
Posted : 30/04/2012 7:12 pm
True say, don't know why I'm moaning at £3, just thought it might be worth a shout. : )
Posted : 30/04/2012 7:14 pm
I used 2 layers of some cheap insulation tape, mainly because I couldn't be bothered going to the LBS at the time.
Posted : 30/04/2012 11:26 pm
used both together, Rim tape first then electrical if more was needed
Posted : 30/04/2012 11:39 pm
I use a couple of wraps of electric tape, because it's cheap and light.
Posted : 01/05/2012 12:03 am
I've used masking tape for the past couple of years with no issues!
Posted : 01/05/2012 8:32 am
I've been using a single wrap of electrical tape for about 2 years now. I dont weigh much and never run high pressures. Also my rims have nothing sharp in em. Even run tubeless!!
Posted : 01/05/2012 8:41 am
3M crossweave tape. Much stronger than lecky tape. Works tubeless too.
http://www.ebay.co.uk/itm/1-x-ROLL-19mm-x-50m-Crossweave-Reinforced-Tape-/180337800112?pt=UK_Packaging_Materials&hash=item29fcf873b0
Posted : 01/05/2012 8:53 am
 cp
I use the stuff reggiegasket linked to - works great.
Posted : 01/05/2012 8:59 am
