Right woodworking t...
[Closed] Right woodworking tool.
[#7900747]
I want to cut the rebate or step out of an old door which has a glass panel this should give me room to fit a double glassed panel instead can i use a jig saw with guide or is this an excuse to buy a router?
I have worded this badly I actually want to remove the rebate leaving a flat surface .
Posted : 21/06/2016 11:39 am
Perfect excuse for a router.
Posted : 21/06/2016 11:42 am
If I've read what you want to do correctly then it's a job for a router.
You need an excuse to buy tools?
Posted : 21/06/2016 11:43 am
Posted : 21/06/2016 12:34 pm
 Gunz
Get a router but I should mention that if you're a newbie to them like myself then the bearing guided router bits, as Kayak has posted, make life a lot easier (everything I own now has some sort of bevelled edge).
Posted : 21/06/2016 12:53 pm
I would use a circular saw for that. Check on YouTube for how to make a simple fence which acts as a guide rail. Unless you have a really really good jigsaw (Festool) the cut will go all over the place.
Posted : 21/06/2016 12:58 pm
