riding over ice
[Closed] riding over ice
 Pook
[#207711]
you know the two inch thick stuff you get on trails this time of year. Is there a particular technique for not losing your front end? Is it just sit bolt upright and get over it quickly?
Posted : 12/01/2009 12:33 pm
and dont lock you brakes up / or turn sharply
Posted : 12/01/2009 12:35 pm
That's what does it forme , no pedal, bar or brake inputs whatsoever. Relax and if you're lucky you come out the other end without a broken elbow.
Posted : 12/01/2009 12:36 pm
Good Karma
Posted : 12/01/2009 12:39 pm
I find sitting in a cafe drinking tea is the best way to deal with ice 😆
Posted : 12/01/2009 12:40 pm
absolute minimum input to bike, try to save any steering for any rocks or grass emerging from the ice. Possibly avoid breathing too.
Posted : 12/01/2009 12:44 pm
sfb is right (good god, did I say that?!)
Posted : 12/01/2009 12:46 pm
Don't pedal
Don't brake
Don't steer
I've actually found the ice improves your riding. Because you know you can't brake or you're dead, i've found my riding is a lot smoother.
Posted : 12/01/2009 12:47 pm
The best way is to yank hard on the rear brake, pop a foot down, push the back out and slid sideways across the ice whilst screaming 'BANZAI!!!!!' as loudly as possible.
....maybe
Posted : 12/01/2009 12:49 pm
Low tyre pressure, sideways and feet out.
Posted : 12/01/2009 12:51 pm
As others have said don't brake ster, pedal or move you're body and you may be okay. But it depends in the length of the icy section as if it's only a bike's length then the bike may regain grip before either end has time to slide out. It's lilley you'll fall off though 😉
Keep your saddle lower than normal too
Don't pedal
Don't brake
Don't steer
So sitting in a cafe is indeed the way to do it
Posted : 12/01/2009 12:52 pm
If its ice tyre pressure wont help you a jot. If its a mix of trail and ice then it will!
Posted : 12/01/2009 12:57 pm
ride round it
Posted : 12/01/2009 1:10 pm
in fact, stay there all the time - if you attempt any riding you may get hurt or tired or sweaty or something equally indelicate 🙁
Posted : 12/01/2009 1:12 pm
Stick ice tyres on, and carry on as normal.
Posted : 12/01/2009 1:13 pm
 will
I found that the other day whilst trying to climb on the stuff in the peaks if you put it in a much lower gear than you usually would do, thus making it very easy, but pedal faster the wheels [i]just[/i] manage to grip the ice.
Such good fun, and such a reward when you manage to clear a section.
Posted : 12/01/2009 1:16 pm
deploy ACME stabilising blades
 igm
Bunny hop it... maybe
Posted : 12/01/2009 2:31 pm
Blow torch attached to a 20mm bolt-through axle perhaps?
Anyone at Fox reading this?
Posted : 12/01/2009 2:34 pm
Think you'd need something considerably more than a blow-torch 🙂
Posted : 12/01/2009 2:36 pm
