Ribble Cycles again...
[Closed] Ribble Cycles again : Does this sound reasonable to you?
 fbk
Received an order from them earlier this week which included a couple of Michelin DH tubes. When I tried to fit one yesterday evening the small nut on the presta valve sheared off (I was only screwing it up loosly to put the innertube into the tyre!).
Just got off the phone to them this morning and the (friendly enough) chap I spoke to said the only thing I can do is send it back with a cover note and they'll "try" and get a warranty replacement off the manufacturer. He added that they "may" just say I've tried to over tighten it!! The thing's clearly not even been fitted!
Given the great returns service the other big name internet companies offer, is this not a bit rubbish or am I being unreasonable?
Posted : 01/07/2010 10:38 am
I guess its only a tube, so just get £1 tesco ones in the future? dh tubes are false advertising anyway, weigh more and puncture just as easily and cost a lot more
Posted : 01/07/2010 10:40 am
 fbk
Just to make it clear - this is a DH specific tube so cost around £7. Still not a huge amount but worth following up imho!?
Edit: but yes alexxx, you may be right, there may not be any real advantage to using them.
Posted : 01/07/2010 10:42 am
If I was living in abject poverty and the fact that I'd snapped a valve meant that I would now have to choose between buying another tube and feeding my family then I might consider phoning the place I'd bought the tube from and telling them that they had to give me another one because I'd broken the first one.
Posted : 01/07/2010 10:45 am
Is it the nut on the outside of the valve or the internal of the valve?
Its kind of hard to understand how it could happen by losely tightening it up,
 fbk
BD thanks for your input - invaluable as ever 😕
Singlespeed_Shep - it's the small thread within the valve that's sheared - the one that you tighten to stop the air coming out of the valve.
Yes, I know it's "only a tube". Call me a tight arse but it's still £7.
Posted : 01/07/2010 10:49 am
You can take them out on most tubes with a stans tool, not sure if it works on michelin though.
Posted : 01/07/2010 10:50 am
One of these bad boys
[url= http://www.stif.co.uk/gear/select_options.asp?productID=6835 ]clicky click click[/url]
Posted : 01/07/2010 10:51 am
 fbk
Hmm thanks for the info - worth considering I guess. I'm not convinced the valve core is removable in these.
It's kind of missing the point though - it's the fact the thing fell apart with gentle pressure having just been taken out of the box.
Never mind. I'll just put it down to experience and stick with CRC/Wiggle/TBC in future
Posted : 01/07/2010 10:54 am
 ianv
As the tube will no longer work because a part that needed to be tightened up failed to do so properly, I would have thought it is reasonable to believe it was not fit for purpose and not unreasonable to expect a replacement.
Posted : 01/07/2010 10:56 am
I'd follow it up - defo - Maybe he was just trying to disuade you 🙂
Got some shorts from wiggle today and the waist seam was not stitched properly so they gone back £28 - money is money 🙂
Posted : 01/07/2010 10:57 am
If it's presta you can just put a new valve core in can't you?
Edited: - that core stuff is interesting. 🙂
Its not really £7 as if you have to buy anohter of similar design is £14
BTW Neil I got 2 packets of DH tubes you can have but I am afraid they are Shraeder I think 🙂
Posted : 01/07/2010 10:59 am
Use a pair of pliers to unscrew the old core - pop a new one in - simple.
Can buy cores from CRC and the like or just nick one from an old busted tube - I always unscrew the core from old tubes before binning them. And I'm sure a presta valve is a presta valve - will be the same for a DH tube.
Posted : 01/07/2010 11:02 am
 goog
you'll be better off asking an adult rather than posting on here
HTH
Posted : 01/07/2010 11:04 am
 fbk
Goog - that's the most informative reply I've had on here for ages. Cheers 8)
I will investigate the core replacement option though.
Rich - I'll be in touch!
Posted : 01/07/2010 11:46 am
I think some people don't know which is which Presta/Schraeder...
The tool says "removable Presta cores" and I must admit I'd never heard of such a thing
Posted : 01/07/2010 12:00 pm
 fbk
SFB - some presta tubes do come with removable valve cores (Schwalbe I think) but generally I don't see how you could remove them. I think you're right, people are probably confusing the two?
Posted : 01/07/2010 12:11 pm
The top bit of he presta thread comes off, (the bit that isn't the same thread as the lock ring)
This doesn't work on all presta valves
Posted : 01/07/2010 12:17 pm
Maybe the ones you've bought in the past, but proper DH tubes weigh more because they are thicker rubber and higher volume, both of which will help prevent pinch flats (more rubber to pinch through, and the rubber is less stretched).
Posted : 01/07/2010 12:22 pm
I'm still struggling to understand which bit the OP stripped? the little twiddly bit right at the top?
Posted : 01/07/2010 12:23 pm
It doesnt matter HOW much the item is, you've paid for it and its not fit for purpose! Given its never been used, then i would hound them on principle. If they have 10 people who have the same issue, then thats £70 more that Ribble have got off punters. If you bought a frame and it had a crack in it before you even built it up then you'd be on the phone sharpish. Dont take no for an answer!
Stick up for your rights as a consumer!
Posted : 01/07/2010 12:35 pm
I bought a football in Asda for my son for £3. We played with it once and left it in the garden. In the morning it had gone soft.
I'm still taking it back for a replacement.
Posted : 01/07/2010 12:40 pm
I'd just call again & ask to speak to the manager & explain to him
Just point out that it would be a waste of everyone's time if you were forced into the position of officially rejecting the goods & instigating paypal disputes or involving credit card companies etc.
Posted : 01/07/2010 12:41 pm
Has anyone pointed out yet that it's nowt to do with the manufacturer and their warranty - your contract is with the shop.
Posted : 01/07/2010 12:47 pm
and higher volume
isn't the volume determined by the tyre and (slightly) pressure ?
Posted : 01/07/2010 12:50 pm
I would just forgot it and move on....but then i bet £40 on Chile to beat Brazil 😐
Posted : 01/07/2010 12:59 pm
