Revolution Triad DS...
[Closed] Revolution Triad DS opinions please for BTW scheme
[img] [/img]hi im limited to grand this time so looking at this from edinburgh bike coop
has anyone ridden one? opinions please
possibly just keep the parts and sell the frame ? thoughts please
DTD
more info on spec here
[url= http://www.edinburghbicycle.com/ebwPNLqrymode.a4p?f%5FProductID=12435&f%5FFullProductVersion=1&f%5FSupersetQRY=C224&f%5FSortOrderID=1&f%5Fbct=c012528c021513 ]null[/url]
This is our first full-suspension Revolution Triad. The frame was conceived as a confidence-inspiring platform for that most tried-and-tested suspension system, the Horst Link.
The forks and shocks are courtesy of the first name in MTB suspension, RockShox. We would be the first to admit that we consciously played safe here. That way, we can guarantee you won't be sorry.
•120mm-travel Horst Link 4-bar suspension system with cartridge sealed bearings at every pivot point. The Horst Link employs a pivot approximately 25mm forward of and 25mm below the swingarm's lower axle. This system helps eliminate pedalling-induced bobbing by neutralising the chain's leverage effect over the rear swing-arm. This translates as improved traction and smoother pedalling when you climb. Simultaneously, it separates braking and suspension forces, so the rear suspension remains active when the rear brake is applied.
•To take full advantage of the Horst Link we spec a RockShox Monarch 3.1 rear shock ('just as good as the ubiquitous Fox R:' bikeradar.com).
•Match the RockShox Monarch shock with a RockShox Reba fork and you can be confident that this bike's front and rear suspension system works perfectly in tandem to help guarantee an authentic and massively enjoyable trail-riding experience.
•Weight: 14.3kg/31.5lb.
•View high resolution image.
•Read our Staff Review.
Frame 7005 Alloy
Fork Rock Shox, Reba SL Dual Air, 120mm
Shock Rock Shox, Monarch 3.1 Air, w/Rebound Adjuster
Headset 1.1/8” Aheadset / Revolution Top Cap
Shifters Shimano, SL-M590
Rear Mech Shimano, SLX Shadow, RD-M662 SGS
Front Mech Shimano, FD-M591
Chainset Truvativ, Fire-X 3.0, 42/32/22t, 170mm
Bottom Bracket Truvativ, GXP External BB Cups
Chain KMC, HG-73
Freewheel Shimano, CS-HG50-9, 11-32t, 9sp
Hubs Formula, Front 32h, 20mm, 6-Bolt/Formula, 32h, QR, 6-Bolt
Rims Mavic, XM117 Disc Rims
Spokes Steel, Black/14G Brass Nipples
Tyres Continental, Mountain King, 26” x 2.2
Brakes Avid, Elixir 5, White, Hydraulic Discs 185mm Front/ Rear
Brake Levers Avid, Elixir 5, White
Handlebar Revolution, Black, 650mm x 20mm Rise, 31.8
Stem Revolution, Black, 80mm, 10 Degree Rise, 31.8
Grips/Bar Tape Velo, Kraton
Saddle Revolution, Trail Series
Seat Post Kalloy, Alloy, 27.2 x 350mm
Seat Clamp Quick Release
Colour Size Price Availability
Fusion Black 17" Was £1,249.99, Now only £999.99 In Stock
Fusion Black 19.5" Was £1,249.99, Now only £999.99 In Stock
Posted : 05/07/2010 9:53 pm
Bike to work scheme FAIL 😉
Posted : 05/07/2010 9:55 pm
thanks sofatester ive been out the loop for a bit so iwould appreciate your opinion on what i could sell the frame for? thanks DTD
Posted : 05/07/2010 9:58 pm
£300 on a good day.
Posted : 05/07/2010 10:05 pm
that would be ok i suppose ?
does it not look rather familiar to a 5 year old Kona coiler air?
Posted : 05/07/2010 10:11 pm
EBC bikes are well made and good value on the whole. I haven't seen that one tho but it looks like good value and well made
However you need to have the complete bike at the end of the year on btw - in theory it still belongs to your employer until that time and they can reclaim it.
Posted : 06/07/2010 12:27 am
bump
Posted : 18/07/2010 11:11 pm
Its heavy for what it is, the Chris Boardman (available from Halfords) 120mm FS for the same money is lighter (28.3lbs vs. 31.5) and has slightly better finishing kit. They seemed to like the CB in the mag when they reviewed it relatively recently too, If I remember right, it got the singletrack recommended seal
Posted : 19/07/2010 1:00 am
