Reverb/seat clamp
[Closed] Reverb/seat clamp
[#8122469]
I serviced my seat post the other day (Reverb) and it was working just fine. I tightened the clamp to the maximum I could using a fixing paste still allowing the post to 'thunk'. On the next ride though the post slid down inside the tube. The issue I have is that tightening it further causes the post to get stuck halfway. I'm not sure but I think I can potentially fix this by changing the seat post for one that distributes the pressure more evenly. Perhaps like this one.
Anyone else tried this?
Original. I think it might be a bit too 'pinchy'...
Posted : 23/10/2016 11:19 am
Looks like your seat clap is inbuilt - how do you change that? I'd say the seat tube is the problem not the clamp- I've got 3 reverbs all different clamps all fine, quite slim too. Torqued to 4nm i think with the post covered in assembly compound or carbon paste and they're all fine.
If you're doing that maybe try the old fashioned coke can shim?
Posted : 23/10/2016 12:15 pm
Is your reverb pumped up to the correct pressure. I had a similar problem but pumping up the reverb to the correct pressure resolved it.
Posted : 23/10/2016 12:28 pm
Ahhh, that could be a gem of info, thanks.
I was thinking of cutting the inbuilt mount off. I thought of using a can to see if it spread the load more evenly, thanks for your thought, it might help
Posted : 23/10/2016 2:13 pm
Nope, pressure is fine, bugger
Posted : 25/10/2016 10:57 am
Eventually, checked air, serviced/bleed and used a can shim and all seems well so far. I guess the tolerances on a steel seat tube are not as tight as we would imagine/like
Posted : 07/11/2016 2:18 pm
