Reverb Sticking in ...
[Closed] Reverb Sticking in Up Position
My three month old reverb is sticking in the fully extended position. It will take several seconds & excessive force to make it descend. However once dropped it seems to work fine. I've tried bleeding which hasn't helped. Any thoughts or should I be sending back under warranty.
Posted : 08/09/2014 7:06 am
 rob2
I had this and re-bled mine but made sure I wound the adjuster out. Did it about 3 times and it was ok. And still ok.
That said I had another one that did the same and when I pushed it down, one of the seals went and no it's sitting in the garage and no longer holds any air. If bleeding doesn't work I'd send it back.
Posted : 08/09/2014 7:26 am
Sounds daft but make sure your seat clamp isnt too tight!
Posted : 08/09/2014 8:43 am
