reverb stelth? wort...
[Closed] reverb stelth? worth the bother?
OK, so I'm thinking about swapping my command post for a reverb stealth. I have had a normal reverb for years without much bother, but having just bought a stumpy with internal routing for the command post. I'm thinking about getting a reverb to suit, how dose the stealth post fair regarding reliability issues?
Posted : 22/12/2015 1:20 pm
No issues so far with my stealth. No external hose to snag is the biggest benefit. Bit of a chew on to remove it for cleaning though.
Had to replace the hose on a regular reverb after snagging it.
Posted : 22/12/2015 1:28 pm
If you have the three position command post then you will find the reverb way better .Trouble is the reverb hose wont fit through a Stumpjumper frame without a bit of frame filing as it is a slightly bigger bore .
It's got to be worth it to get rid of the stupid loop of hose that you don't think is a problem until you get a stealth.
Posted : 22/12/2015 1:32 pm
