Hi all, just did a re bleed on my stealth dropper. All went well but there is still vertical movement in the post (maybe 10mm).
Pressure was down at 170 so used shock pump to get it back to 250psi.
What do I have to do to sort it myself? Is the full strip down easy? I want to know how to fix it at home.
Any help appreciated.
Ells
Posted : 03/03/2017 11:50 pm
It's probably a full rebuild that's how I cured mine. The videos on srams website are good and you don't need all the specialist tools. I did buy them though
Posted : 04/03/2017 12:16 am
Cool. Basically seal kit then? How much oil did it take to bleed?
Did you replace the brass pins?
Posted : 04/03/2017 1:05 am
