reverb stealth opin...
[Closed] reverb stealth opinions...
new frame arrives thurs/friday this week which will take a reverb stealth, currently i run a non stealth reverb but toying with selling it and going stealth.
obviously the stealth would be neater but is it a faff to bleed or even top up with air? do you need a bit of extra cable tucked into the frame for raising the seat (to top the air up)
also can they be had under £200 anywhere?
ta
kendo
Posted : 21/10/2014 9:18 am
If you're interested I have a brand new Stealth reverb 125mm sent by Planet X in error (should have been a non-stealth). I've used the remote from it so you'd have to swap yours over / find a new one but otherwise its mint. It's a 30.9mm dia btw.
Happy to sell on for £100 posted
Posted : 21/10/2014 9:30 am
could be interested....
could you mail me with the details? 420mm 125 drop etc? full lenght cable?
cheers
mark
Posted : 21/10/2014 9:38 am
yes will mail you now
Posted : 21/10/2014 9:46 am
The air valve is in the top of the post under the seat rail cradle.
No more of an issue to bleed than the normal one (only ever had to do it once in the last 3 or so years).
Best post out there IMO, as long as you have the space (or arn't weird with how you run your bar setup) to flip the lever.
Posted : 21/10/2014 9:48 am
I have a stealth.. wouldnt have another..
Probably going for a KS Lev Integra when it finally dies.
Posted : 21/10/2014 11:33 am
 gogg
Happy with my stealth, definitely neater for routing.
Posted : 21/10/2014 11:45 am
Was easy to install, no bleed needed.
Didn't leave lots of excess hose, I figure you just take the button off the bars if you want to pull it out.
Posted : 21/10/2014 2:12 pm
