Reverb Stealth Expe...
[Closed] Reverb Stealth Experts
2 Users
I have 1 stealth which (after 5 years of service) has started to dip a bit
It's now surplus to requirements, so would like to service it so it's back to full working order, and then sell it on.
Assume I need a seal kit and IFP tool - anything else needed? Is there a decent onlien guide to the job that's specific to the stealth?
SRAM videos seem to be mainly for the standard post - and the service kits too.
Posted : 18/05/2017 4:24 pm
forget about videos this'll see you right,
[url= https://sram-cdn-pull-zone-gsdesign.netdna-ssl.com/cdn/farfuture/Sqxx_P0dlnEfAfe89tEcxHOHxHk5y8P7_a6v8zv_BDI/mtime:1461247391/sites/default/files/techdocs/gen.0000000004211_rev_e_2014_reverb_stealth_sm.pdf ]Click[/url]
You'll need some good soft jaws for the vice and a way of measuring the fluid height, I used a piece of copper pipe and silicon hose attached to a syringe.
Posted : 18/05/2017 9:55 pm
So the various tools aren't really needed? If too etc?
Posted : 18/05/2017 9:59 pm
So the various tools aren't really needed? Ifp tool etc?
Posted : 18/05/2017 10:01 pm
Yes, you will need the IFP tool.
Read the service manual a couple of times to try and understand it. It makes a lot more sense when everything is out in front of you and it's not that complicated.
Edit
If your post is 5 years old it'll probably be needing a new top cap as the bush will be worn.
Posted : 18/05/2017 10:10 pm
Cool, thanks for all that.
Still not sure it makes sense to repair it to sell with CRC knocking them out for 170 euro
Posted : 19/05/2017 8:24 am
