Stealth reverb bleeds easily, works perfectly.
10 or so cycles of the remote later and it's goosed. Remote stops returning and post won't release. Needs bleeding again.
New hose and barbs fitted as I originally thought the problem was a damaged hose.
Any ideas?
have you bled the post itself?
No, do I need to?
When I fitted my stealth, despite having a connectamjig thingy I couldn't get it to work tidy after I shortened the hose at the remote end. I bled and bled it, thinking the other end was fine because the connectamajig meant it didn't need bleeding right? Wrong. 2 mins with a proper double syringe bleed of the post and voila. Perfect.
Sorted. Barb fitting at the post end was leaking. Re-cut the hose and refitted and seems fine so far.
You don't bleed the post with the syringes, only the hose & remote.
