I've been doing some research and it appears that I can't fit a reverb.
Minimum seat height is 195mm from top of seat clamp to centre of rails, I run 185mm and would rather not be hunting for this point while riding.
I have 380mm from centre of seat rails to the stop on my frame.
Am I right in thinking the 100mm reverb would be shorter in the rails-clamp dimension? Or should I just start looking for a non-reverb dropper?
See if [url= http://singletrackworld.com/forum/topic/small-frame-seat-post-reverb-quandary?replies=22#post-4134655 ]this thread[/url] has the info that you need on the 100mm Reverb.
I believe it does!
Looks like 100mm drop posts are 165mm clamp to centre of the rails. Will get the tape measure out to see how that would work 🙂
Ta!
