Reverb dropping abo...
[Closed] Reverb dropping about 1 cm when I sit on it, oil in air chamber
Checked the air pressure and it was low but quite a bit of oil in air chamber which squirted out of the valve
suspect a seal has gone?
is this likely to be serviceable?
thanks
Posted : 04/04/2016 7:41 am
How old? - 2 year warranty on Sram kit
Posted : 04/04/2016 7:56 am
Yep, mine did this.
Warranty job.
Posted : 04/04/2016 7:58 am
bought on classifieds!
Posted : 04/04/2016 8:01 am
 Alex
It'll be the oil level. You can do it yourself - the videos on the SRAM site are excellent. But you need the SRAM measuring tube or a copy of one to get the oil levels right.
Posted : 04/04/2016 8:15 am
 Robz
It might just need bled but mine has just gone back to SRAM for this very reason.
Posted : 04/04/2016 8:21 am
Mine is doing the same ๐Ÿ™
Posted : 04/04/2016 8:32 am
Yep - two of mine did this and it was fairly easy to top up the oil which fixed them..
Posted : 04/04/2016 8:56 am
A bleed WILL NOT fix this known problem.
A service will.
Warranty it if you have the option. You will likely get a new post back.
Posted : 04/04/2016 9:34 am
I've got the same problem.. but I bought the post from the classifieds.. what is the cure?
Posted : 04/04/2016 9:45 am
Get it serviced. Either yourself or by TFTuned, Loco etc.
Posted : 04/04/2016 9:46 am
