Reverb creaking
[Closed] Reverb creaking
10 Users
My fairly new Reverb is creaking somewhere in the seat clamp area. Is anyone else experienceing this? I have greased the bolts and the retaining nuts and it goes away briefly but then comes back.
Anyone got a lasting fix?
Posted : 18/06/2013 10:00 am
Check that the screw in plates are oriented the correct way
Posted : 18/06/2013 10:03 am
Dry weather init, moment it rains mine stops creaking
Posted : 18/06/2013 10:05 am
I've had this. It seems that you need to make sure both bolts are done up evenly. Cleaning the rails and putting some grease in there won't hurt either.
Posted : 18/06/2013 10:08 am
Grease everything. Take the clamp apart, clean all the parts carefully and then grease every area where metal touches metal, clamps, captive nuts, under the bolt heads, on the threads and particularly around the saddle rails themselves. There's always movement at the rear of the rails and movement means creaks. As mentioned above, make sure the clamp plates face the right way, there's an arrow on each one that should face forward.
Posted : 18/06/2013 10:09 am
using carbob paste in the seattube?
Posted : 18/06/2013 10:10 am
mine did this - give the clamp area a good clean and re-tighten
Posted : 18/06/2013 10:11 am
Cheers - will try all of the above.
Posted : 18/06/2013 10:32 am
As above, mine turned out to be the saddle/clamp area, rather than the post/seattube area. Strip - grease - refit.
Posted : 18/06/2013 10:36 am
Also check the silver collar is tight
Posted : 18/06/2013 12:17 pm
I thought the silver collar was for emergencies in case the seatpost failed - it enabled you to keep it at a fixed point. What are you using it for?
Posted : 18/06/2013 12:51 pm
The silver collar you're talking about is a travel limit collar for Enduro racing and the like. In other words its so you can drop the post just a bit easily and quickly and still be able to pedal without our knees being around your chin.
The other silver bit that might be referred to above is on the older Reverb models and is the top part of the external assembly. Checking that is tight would definitely help 😀
Posted : 18/06/2013 2:39 pm
