£180 less 10% for the code 10-extra (thanks DSB181).
Just about to... [i][b]'post'[/b][/i] this deal 😉 ha ha ha ha ha ha ha ha ha ahhh...
Thanks anono
Can you also use the £5 off if you subscribe blagg with the 10% code?
...apparently not.
I just got one! Thanks for the info and discount code!! 🙂
i just got one too! thanks for the info, i have been waiting for a good deal!
Nooooooo! I did not need to see that. Oh go on then.
Many thanking yous 🙂
2012 model???
yep 2012
Discount code does not work ??
You bad people...I was planning on buying one, just not yet!
Best part of forty quid cheapaer than the Germain sites too...
Only got the 4" drop ones left.
Mine shows the 125" drop instock still
There seems to be stock of 125mm drop in 31.6.
Either way, don't forget your Quidco 3% cashback, saves you almost another fiver!
Opps sorry it does 🙂
Where's the best place for the remote, is buying a right then having it one the left under the bars the best place?
Yep got that too many thanks guys 🙂
Seems to be
buy the right one then place left under bar.
Got myself excited, only to be let down as the Right 30.9mm 420mm 125mm drop post is out of stock, and I don't think the 100mm drop would be enough for my 6ft3in size 🙁
^^ Me too. 🙁
Many thanks for posting this deal.
I've been keeping an eye out for a new Reverb and was waiting for the exchange rate to improve to get one from Germany. This deal is even better value (about £30 saving and free delivery) and easier to return for warranty issues!!
Thanks for the heads up on this, just got myself a 31.6 125 drop post:-)
I'm on a medium frame and only 5'9" so should I go for a 380 or 420 post?
How much post do u run out of frame currently?
I'm similar and I'm going for the short one I think.
It still seems barmy to pay £160 for a seat post... but I SO WANT ONE!
Cheers for that, just missed out on one that I had [b]agreed[/b] to buy nearly new for £150. Only to be let down when he sold it to someone else for a few quid more.
Well chuffed now.
Numpty question as iv,e always had KS droppers.MMX??.Can it just be used as a normal clamp...
£ 153.00 with free delivery 😀
Happy days.Off goes the ks to the fleabay 😀
It's not £160 for a seatpost, it's £160 to transform the ride of your bike.
About this much, sorry about the picture, it's the only one I have
380mm prob would be spot on
ROFL! I've been trying to use the voucher code DSB181 for ages!
I did that too. Doh.
Not just me as well then!!
well, I hope you're right! one is on its way.
you can quote me
oh, you did
What is the difference in model years 2012 and 2013?
I've just bought one...was going to get one in the summer, but this is cheaper and from a UK company so I thought sod it!
No more faffing with QR seat posts...only downside is that I need to buy a new saddle now because I am currently running an I-Beam jobbie.
Cheers guys, I've got one on the way!
Do they come with a bleed kit?
Just sucked me in too with the appearance of a 125mm travel one in 30.9mm. Must be a fair amount of stock knocking around. Back to height adjustable bliss.....
Voucher code no worky 🙁
Worked for me Mark literally an hour ago.
Just trying to decide on a new saddle now - I really like my I-Fly but am a bit tight to pay £70 for the Ti railed version.
I may just nick the spoon from the BFe for now until I can track down a white Knife (I prefer slimmer / harder saddles).
What code are you using?
The one in the original post.
10-extra
Ahhhh.
Done. Thanks or the heads up on that one. As at 2pm today there stock showing in all sizes/lengths/drops etc.
Get em while they're hot!
Been holding off a remote post for ages now ... decided to take the plunge! Cheers for the heads up.
Bought here too.
As all the drop down boxes are not working, i presume they have sold out of certain length/drop combos?
@mindmap I have a ti rails White Knife that needs a home, it's as new (ie fitted but never ridden). You have no mail in your profile, mail me. I have a black one, a bit used, too.
Can you buy the bar clamp separately if you don't have sram brakes as they only seem to have the MMX ones in stock?
X-Fusion Hilo also cheap. Just got one for £125 with the discount code!
I believe the 2012 are all mmx but come with the block to use as conventional setup alongside the shifter etc
What does MMX mean? (Have I bought an unusable Reverb?)
No, its just the special adaptor clip if you want to attach sram shifters to the clamp. Presuming its just the same as my last one where you just leave the adaptor in the box and use the clamp as normal. Personally prefer a right hand lever so i can run it under the bars on the left.
Saw this thread last night but the size I wanted had sold out.
Checked again today and they were showing stock again so ordered one.
I went for a 30.9 even though my frame is 31.6 because of have 2 other frames that are 30.9.
I presume 30.9 are more popular anyway and would be easier to sell 2nd hand should I ever need to.
& part of Wiggle's terms are you get a year to return it (unused)
matlockmeat - thanks for the head's up - oos last night and in stock today. result!
Got myself a USE shim for around £5 as well. Hopefully this post will live up to the hype.
I had no idea you could get a 30.9-31.6 shim - nice one!
I didn't either. They seem less common but wiggle do them.
I looked at a mates before I bought and they are good quality.
Early birthday present for Mrs. L - done 8)
Mattjg - email sent about the saddle.
And it's just bounced back twice...
Any chance that you could drop me a line on sam_t_court AT hotmail DOT com
I went with a 30.9 and bought a 31.6 shim so I could use it between two bikes 🙂
Thank you for the heads up 8)
From reading the Q&As it seems they come with a bleed kit too.
Bargainous 😉
Didn't use it for the dropper but I have just used the code for three chainsets so thank you very much to the op.
Mine has just arrived.
Boxed stock with full bleed kit etc in original packaging 🙂
Looking forward to giving it a try out.
Thank you OP for the heads up 8)
letmetalktomark - good to know!
Looking forward to mine. My Joplin died in November and I've been lost without it!
Mine should be here today...off Friday too, so looking forward to giving it a whirl.
Mine turned up sat pm, retail packaging, bleed kit etc,,
Well happy 🙂
Just tried to order and I'm getting a "Sorry we are not able to ship the items in your basket to United Kingdom. Some items cannot be shipped to some countries due to selling restrictions and regulations." message.
Anyone else getting this?
Yep... me. Just mailed them
Looks like the offers gone and I was just about to buy one.
It's been sat in my basket for the last 4 days with me wondering if I really need one.
Can you hire them from somewhere, to test?
Keep an eye on it. They restocked halfway through the offer, so they might try and get more again.
On the other hand, they might not be able to get any more 2012 models.
mines here....didnt expect the bleed kit to be incuded. well happy. only ordered friday pm
Mine also arrived this morning, very happy thanks op.
If anyone missed out, I bought one that didn't actually fit the missus bike. Arrived today, swift test after half unpacking it, miles off, flogging for whatever I bought it for (or returning if no one wants, seems worth passing on a decent saving like that, they're £225 again).
It's on the classified.
Bought one the day before and was shipped yesterday. Hopefully I get it tomorrow.
Thanks anono for telling me about the offer but the code didn't work for me.
Anyone who is still wanting one can use the code 10EXTRA.
