revelation RL 29er ...
[Closed] revelation RL 29er help
9 Users
Does anybody know the hight for these forks at 120 and 140mm please.
I can't find any info on the website.
Cheers in advance 8)
Posted : 09/07/2012 7:10 pm
Mine are 530 set at 120mm (and I assume 550 at 140).So says my tape measure about 30 seconds ago.
Posted : 09/07/2012 7:14 pm
Pretty sure its 525/545mm will need to check though
Posted : 09/07/2012 7:15 pm
Anyone know when the 2013 120mm 29er Rev's will be available?
Going to dress my Solaris with them soon 🙂
Posted : 09/07/2012 7:17 pm
Rep told me august(ish).15mm only.
Posted : 09/07/2012 7:19 pm
thanks for the help guys. i guess its better over here in the 29er corner. *throws away razor!
SO what are you all riding?
Posted : 09/07/2012 7:20 pm
 bol
I'd be tempted to take a quick look at On One if I was in the market for 29er revs right now. Sadly I'm not. £299 while limited stocks last...
Posted : 09/07/2012 7:21 pm
Yelli.
Posted : 09/07/2012 7:25 pm
 LoCo
The solo air 2013 Revs 29er model(max 140mm) will be available at the end of the month, however they are only available in RCT3 flavour with a tapered steerer and 15mm maxle, aftermarket from Fishers (uk Distributor for Rockshox)
Can you make 140mm Rev's 120mm?
Does it just limit the amount of travel or adjust the axle to crown length?
I plan to put 120mm on my Cotic Solaris when it arrives 🙂
Posted : 09/07/2012 7:26 pm
Damn thats a deal!!!!!!!!!, just be aware that the DPA cannot be reduced in travel below 130mm (and is allegedly a bit ropey on the reliability front)
It says 120-140mm travel adjust though?
Posted : 09/07/2012 7:28 pm
Thats through the DPA though, its temporary like ETA on Zocchi forks
Posted : 09/07/2012 7:29 pm
Description of DPA from SRAM;
An easy-to-use detented knob offers long and short travel options with a turn and a click. With approximately 30mm of sag-to-sag travel adjustment, it is designed to simply bring the front of your bike down for climbing prowess. Dual Position Air is sweet and simple, smooth and robust. Bomb downhill with confidence. Click. Climb like a demon.
Think I was talking rubbish SRAM does not state anything about internal adjustment of travel on this model. 😳
Posted : 09/07/2012 7:34 pm
So, do you think the 140mm could be run at the lowest setting all the time then?
Making them like 120's?
As in it will lower the front end and reduce axle to crown length?
Posted : 09/07/2012 7:42 pm
 bol
They'd go so nicely on my RIP 9. If only I hadn't just spent all my money on a road bike.
Posted : 09/07/2012 7:58 pm
Too late they are all gone 😯
Posted : 09/07/2012 8:00 pm
There were 7 an hour ago!
Posted : 09/07/2012 8:01 pm
Should make a bit of profit selling them on ebay 8)
Edit; That should have been 😉
Posted : 09/07/2012 8:04 pm
I got the last pair! 😀
Hope they can be wound down to 120mm!
It does say that in the description, if not as above Ebay them and make £'s! 😆
Posted : 09/07/2012 8:17 pm
Altough my order went through to On-one for a pair, they seemed to have 'sold one too many' - ???
Is what they told me 🙁
Posted : 10/07/2012 9:13 am
I got the first pair!
Im thinking a RIP9 build coming on!
thanks for all the help guys!
Posted : 10/07/2012 4:55 pm
I've got a pair coming...apparently you can swap a dual air cartridge for the DPA cartridge?
Posted : 10/07/2012 5:13 pm
Mine came this morning, how can I convert them to non poploc so I can adjust the compression?
Posted : 11/07/2012 12:01 pm
Anyone got and fitted / used the forks that On-One were selling? ( for £299.99 )
Can you actually wind them down to 120mm like U-Turn's?
The fly boys have put them up to £399.99 now! 🙁
Posted : 24/07/2012 7:21 pm
 LoCo
First drop of 2013 Rockshox stuff has just arrived, no 29er Solo air revs yet but 26ers are in stock 😀
Posted : 02/08/2012 11:57 am
mine are still in the box, how are the forks going?
Posted : 20/08/2012 5:20 pm
Happy with mine... Running them the whole time on the shortest setting (110) on my Solaris.
Posted : 26/08/2012 6:26 pm
