Revelation forks, p...
[Closed] Revelation forks, play after a professional service.
Right, i've just had my forks serviced by tf tuned, im confident they've done a good job and sorted out some issues for me.
However, i feel play in the fork, similar to the 'loose headset' feeling, definatly from where the uppers and lowers join.
Its defo there and not the headset or the brake.
Its only a small amount, but dont have this in any other fork i own, or any friends forksi've felt.
Should this be left or addressed?
Posted : 10/06/2014 10:25 pm
Go back to TF first if your not happy
Posted : 10/06/2014 10:28 pm
Sounds like the current "issue" with the new Pike might be contagious
Posted : 10/06/2014 10:48 pm
Dont know of said pike issue?
Its not enough to be felt when riding, just when tinkering in the garage, always try to keep the bike tip top...
I have spoke to tf who said they will happily have it back and tighten bushes but it will be better for small bump as its plush and if the bushes are too tight it can suffer..
On brand new revs this play isn't present? They always seemed plush enough for me.
Guess what im really asking is does/ would anyone else run a fork like that?
Posted : 10/06/2014 11:04 pm
Is it only when they are topped out or when they are down in the travel a bit? Only when topped out is normal and won't be noticed when riding. Down in the travel and still moving is too slack.
Posted : 10/06/2014 11:12 pm
Will have a better look at that tomorrow cheers robin
Posted : 10/06/2014 11:14 pm
Is it a dual air or a solo air?
Posted : 10/06/2014 11:19 pm
I have the same slight play in my Revelation forks.
Posted : 11/06/2014 7:11 am
Dual air
Posted : 12/06/2014 2:28 pm
Had similar play tightened in mine, but it did make them less plush. if you cant' feel it riding, might be worth leaving it.
Posted : 12/06/2014 2:46 pm
