I need to adjust bar and shifter set up on my road bike, and I'm going to to put on some better bar tape, which I've not actually done before.
It looks like a straight forward job, I envisage an evening of peaceful and productive pleasure in the man cave whilst supping a fine ale.
What idiot errors do I need to avoid to prevent my dream shattering into a screaming sobbing mess of frustration
May not be definitive but:
Adhesive strip should contact bar not tape
Don't forget to wind in the alternative direction for left and right sides or you will cycle round in circles
Don't use the finishing tape in the pack, use some electrical pvc tape to avoid unnecessary swearing
don't forget the little bits that go behind the shifters.
Make sure you don't tape over any of the rubber bung holes in the shifter so the cover wont fold back neatly.
Make sure you leave enough overlap at the ends to tuck in so there's isn't a bit sticking out when you put the end plugs in.
I'd agree with this usually but lizard skin dsp end tape actually sticks.
Use black bar tape so that it doesn't immediately look grubby. Certainly never use white tape.
make the adjustments first. otherwise you'll be fiddling with the controls & trying to retape using already cut tape. 😳
Keep a decent tension in the tape (probably more than you may initially think)
Tear off the backing tape as you go.
Have a dry run around the shifters with the backing tape on before you do it for real.
I do actually find it quite relaxing, it's on my list of jobs for this week and I'm quite looking forward to it.
There's loads of guides on YouTube and they all roughly say the same thing although there is some debate about which direction to tape in. Personally I'd just do in whichever direction it's currently taped in.
Some general advice that I've learned through trial and error:
Take a pic of the tape on both sides looking at the tops and the drops. You only need to do this the first couple of times but it's a good reference point. Don't unwrap both sides before panicking about what to do next...
Have some scissors to hand and the electrical tape ready to go. I tend to find the end and stick it to my top tube as it saves finding the end whilst also trying to hold your freshly applied tape in place.
Related, don't faff with the finishing tape your provided, just bin it and use electrical tape.
If you don't like the wrap undo it straight away and you'll be able to re-wrap with the same tape. Wait a day and the tape is well stuck down making the task much more difficult.
Watch lots of vids about how to do the area around the hoods. There are various methods with various merits, find the one you like and watch that vid a few times, hell, have the vid on your phone ready to go incase you need to refresh your memory.
Hope that helps.
I found the 'figure of 8' method round the shifters gives the neatest finish, but as above do a dry run first.
start from the top of the bar, not the end, (makes it easier to make sure they're about even looking)
Make a nice cup of tea before you start.
That's a good point; I have a bit of electrical tape ready that's enough to stick the end in place, and then I go over that with two or three full wraps.
...or open a beer 🙂
The starting from the top thing makes my head hurt even thinking about it.
Whaaaaaaaat? That's crazy talk! 😯
The correct placement of these is the bin.
I remove the backing take and stick some double sided on the bar and a pieace all around the end.
nickc - Member
I can't see how that makes a difference.
It also leaves the end must susceptable to unpeelimg if you lose a plug.
Trying to figure out if this is good advice or not, would you not end up with the overlap the wrong way round by the time you get to the drops? 😕
Just buy some tape with the silicone adhesive, this seems to allow infinite retaping, and you don't end up with chunks of tape stuck to your bars way down the line.
I know it sounds heretical, but I kind of like using a strip of double sided sticky tape at the start of the wrap (i.e. where the bar bung goes). Means you can stick the tape down and don't need to faff about getting the right amount sticking out to secure the bar bung properly etc. I always struggle to get this bit neat.
Use silicone tape. It has no adhesive but just grips and you can unwind it millions of times when you cock up.
Arundel is half the price of Fabric or that American stuff.
When you undo the existing bar tape, you should find that the brake and gear cables have been taped against the bars in a few places with some electrical tape. It's unlikely that this has not been done, but if not secure them in position yourself with electrical tape before fitting the bar tape.
My leather tape does seem to be quite sensitive to taping direction. If you're sat on the bike, then right hand side is clockwise, and left anti-clockwise, otherwise the tape curls over a bit.
Give the end of the tape an experimental tug before you start winding it so as not to discover how tight is too tight to pull just as you clear the lever.
Definitely start at the bar end not the top and expect to need electrical tape to secure the end. I have been known to use Gorilla tape for this though.
One of my favourite jobs. Always from the bottom (so the joints are flat as your hands move down the bars). Looking forwards: clockwise RHS, anti-clockwise LHS. Expect about 9-10 wraps before hitting the shifters. Try a figure of 8 and don't forget to reverse it on the opposite side! More overlap on the top bend and head for home. A nice bevel cut off the end of the tape to give a squared off last wrap, and finish with electrical tape. Black. Add nice posh tape over the electrical tape if you must.
Expect to unwrap the first side three times and the second twice 😉
EDIT. The only exception for taping direction was my TT bike, where I went up the bars to the ends, so they are taped both ends and moar aero 😉
Most things I was going to mention have already been covered.
Be patient and stay calm. Be prepared to unwind it all and do it again properly. Make sure you know how to go around the levers (a few different ways of doing this including figure of eight or using the extra bit).
Whatever you do don't start at the top of the bars or be prepared to be laughed at for the rest of your brief roadie career.
Don't leave home with shonky bar tape.
Bar tape on radiator to get nice and sticky, or pritstick on bars
Don't be mean on the bends - check the outside of the main bend just under the shifter for gaps as you wrap. Then as you pass the shifters, pull the hood down into situ to check for more gaps.
Wrap your bars completely in electrical tape - the bar tape can be wound and unwound as many times as you like until you get it how you want it, plus it doesn't leave a sticky mess when you come to replace it. I've re-used bar tape umpteen times. Also worth leaving the tape on a radiator beforehand as it makes it more stretchy,
Some very helpful advice and very little piss taking. I'm both pleased and disappointed!
Don't buy two-tone tape. I will never ever ever do that to mine again, was not worth the ridiculous amount of effort to get it right.
Don't practice with expensive tape.
Don't do your first time with Lizard Skins,it's a PITA.
Make sure the tops are wound back towards you or they WILL go loose.
Using Electrical heat shrink to finish looks very neat.
Wrapping past where you want to finish then cutting with a very sharp scalpel leaves a nice square end.
Figure of 8 behind the hoods can make it very bulky with thicker tape.
Get the distance from the stem EVEN!!!
Take your time to get the overlaps even (bit closer is allowable on the tops for more padding).
I've had people with calipers check the evenness of my wrapping 😕 .....a 2mm variance was 'not ideal but acceptable'
Stiff drink to steady the hand, then as described above.
One school suggests some heat shrink tube or cut up inner tubes slid onto the bars before starting makes for a neat finish. IMHO Insulating tape can look ok, but tapering the end of the bar tape helps enormously.
Do not under any circumstances start at the top. It is not the answer.
Three quid tape from Decathlon is good for practice before you use the posh stuff.
Nah, it makes no difference in reality, just which way you're used to doing it. and I know of one pro-mechanic who wrapped outside-in...
Envisage about 10 minutes of peaceful and productive pleasure in the man cave.
[b]START FROM THE BOTTOM FFS!![/b] Else the bar faeries wii come exact their revenge in the dead of night 😯 Keep the tension up or it'll all shift over time and water etc will work its way behind. Cut the end of the tape at an angle as you finish. Electrical tape is your friend. Don't rush it!! My 2 pennies worth - good luck! 😀
I've got to do this too. How long does it actually take 1st time? We talking hours?
^^^ No! 🙂
Figure of 8 and the 3 finger measure from the stem outside is about the right place to stop. I like to finish with a single width wrap of electrical tape that doesn't spill onto the bars.
I'd always tape bottom up.
When your hands are resting on the upper bends or just behind the hoods, the force from your arms is pushing down the bars. If you tape from the bottom, you will be pressing the free edge of the tape down. Tape from the top, and your hand pressure will be peeling the free edge away from the bar.
Get a cork and stuff it in the end of the bar. Start your taping from there (pinning the tape to the cork helps). When you're finished, trim the tape off the cork, remove cork, and tuck the surplus in to the bar.
I never cover the bit around the lever clamp and leave a small gap, but then I quite often leave the tops untaped.
yes always start at the bottom of the drops as the video on page 1. don't wrap too thick at the bottom of the drops, you don't spend as much time there as you do on the tops of the bars
I speak here as a man who considered (but rejected) taping over the hoods to stop sweaty hand disease, so take what you will from this
I tape from top down - requires no electrical tape which is enough of a winner for me already. I've never had tape work loose on any part of the bar. I start waaay further out than most people do.
I actually like the slight ridge at the leading edge of the spiral when I'm on the drops - feels "grippy". Probably costs a watt or so in aerodynamics, if you count those things.
I don't fig 8 it and I don't use the extra bit either and I don't care what anyone thinks. To make it worse, my bars are white (they were cheap, okay) and pretty much all of the rest of the bike is black
I overlap it quite a lot and I use gel underneath - I believe "bite me" is what some might say here
for the final nail in my coffin - planet x non-slip tape is actually quite nice
Don't worry Flash. Profile will be deleted within the hour (assuming there's any vestige of decency within me 😉 )
Here is a very instructional bar tape video from Brazil. I believe that the woman is very experienced.
I taped mine for the first time a couple of months back, quite enjoyed it once I got started, I just kept pausing youtube as I went...
lots of good advice above, however this from Tired is fact :-
Back in the days of thin cloth tape, some of us thought the classy thing to do was to use 3 or 4 tapes with no adhesive and braid them up the bar, thus getting a line of diamond shapes (and a slightly thicker grip).
With no adhesive on the tape, it was easy to undo the mistakes and redo it. The ends were neatly bound with whipping line. Then a thin coat of lacquer to fix it all in place.
I have been meaning to do it again on one of my vintage bikes.
Ooh yeah, this ^
I was forever deliberately overlapping the electrical tape onto the bars, the thinking being it would contain everything better and look neater, but of course it didn't, the electric tape just folded in on itself and looked crap (not helped by the fact that I like thick tape, wrapped thickly).
Bring the electrical tape only as far as the edge of the bar tape, ideally cut so there's no weird overlapping. Looks v.neat and tidy.
I always try get it to the end of the butting (i.e the end of the thicker central section). Do it right and the tape blends into the butting leaving what looks like a constant diameter of bar.
only if you are doing figure of 8 at the shifters 🙂 If not, clockwise LHS and anti-clockwise RHS, so that on the tops, the tape wraps from front to back, to mirror hand pull force that will be exerted.
Don't waste you life, money and handlebars for ribbon with glue.
Use tape on silicone-strip base. It leaves your handlebars clean, allows for infinite number of corrections, makes re-taping 10 minute job and hold as good as stuff with glue.
Cheers!
I.
When you're experienced, taping the bars should be a 15mins job you can do just before going out for a sunday ride with mates with fresh tape.
I usually buy £12-18 tape and change more often.
-from the bottom
-don't stretch it much if it's gel/silicone (the comfort is gone if stretched)
-wrap closer in the drops and just after the shifters (more comfort)
-figure of 8 around the shifters (bin the small piece)
-stop it when the bar tapers to 31,8mm --> electrical tape.
combine these videos:
As above is the way I do it, apart from
Why would I start fannying about just before going for a ride? If I needed to change bar tape I'd do it when I had nothing else to do.
