Replacing Hub Beari...
[Closed] Replacing Hub Bearings...or any bearings!
[#2780231]
Never done this as yet on my voyage of discovery on all things regarding bike mechanics.
Looking to change the bearings on a rear wheel (the hub is a 150mm Superstar). I have the replacement bearings on order, hopefully here today or tomorrow.
I got the 2 existing bearings out with a bit of brute force (rubber mallet and long handle torx driver). But they needed a good battering to get them out. My question is will the new bearings need the same amount of force to go back in fully seated? If so I'm pretty sure I shouldn't be battering them in the same way as the existing ones came out or they'll be damaged. Do I need to buy a press or can it be done carefully 'sans' correct tools like many other jobs I do...if so how?
If I do need a tool, any recommendations.
cheers
Posted : 23/05/2011 12:30 pm
Usually, an appropriately sized socket is best for pressing bearings in, tap it with a mallett, and grease it up before it goes in. IME the first time you remove bearings from a hub, they can be very tight, then after that the process gets easier. 🙂
Posted : 23/05/2011 12:52 pm
Getting em out is always more difficult IME, they push back in fine using a correct size socket - that matches the 'outer' race NOT the inner.
You can always pop the bearings in the freezer for a few hours first, and/or soak the hub in boiling water to help the process along
Posted : 23/05/2011 12:55 pm
Ahh, cheers guys. Good advice again. I didn't even consider using a socket...there I was considering getting something fashioned up from hardwood or something 🙄
cheers again
ps Peter I got the clips for my specialized as well cheers. got them from Dave Mellor cycles as suggested by someone on the thread so all's good.
Posted : 23/05/2011 1:24 pm
z1ppy
this makes a huge difference - well worth doing
Posted : 23/05/2011 1:28 pm
Ahh, good! I did have a look, I've got 3 spares and I wouldn't really have wanted to sell 2 of them to be fair! 🙂
Posted : 23/05/2011 1:33 pm
TJ - cheers. Assume you mean stick the bearings in the freezer? I don't fancy the hot water option as the hub is part of a fully built wheel although I could always stick the wheel in next to the Mrs when she's having her bath tonight... 😈
I'll do the freezer bit. It works with headset cups so I suppose bearings will be the same!
Posted : 23/05/2011 1:39 pm
Bearings in the freezer - hubs in hot water - all you need to do is tie a rag around the hub and pour boiling water over it
Posted : 23/05/2011 1:44 pm
