Replacement bearing...
[Closed] Replacement bearing cost for front DT Swiss 240 hub??
Anyone have any experience of the above?
Posted : 24/10/2012 10:23 pm
Depends on what brand of bearings you spring for - genuine DT Swiss will be expensive but good, ditto SKF or similar, no-name bearings off eBay will be cheap but probably nasty and not last as long.
It's one of those how long is a piece of string questions. Kaesee's eBay bearings seem decent enough and reasonable value if you want a sort of halfway house.
Posted : 24/10/2012 10:27 pm
I'm no mechanic but I'd have thought getting anything less than DT bearings would negate the benefits of using such top line hubs...?
I have absolutely no idea of the cost of hub bearings having never had to replace any.
Posted : 24/10/2012 10:34 pm
Front hubs are mostly just a tube with spokes and a bearing at either end, nothing dramatically exciting. See:
[url= http://singletrackworld.com/forum/topic/dt-swiss-240s-front-bearing-replacement ]
http://singletrackworld.com/forum/topic/dt-swiss-240s-front-bearing-replacement [/url]
SKF bearings in that size, assuming it's correct, will cost you around a tenner each on eBay. They're top notch bearings and will be pretty much the same sort of level as the ones DT Swiss use themselves. I have a couple of their rear hubs and both have been rebuilt with SKF and have been fine for ages since.
Posted : 24/10/2012 11:05 pm
Ok cheers. Really am struggling to see how a 240 front hub can cost over £200. But people buy them still...
Posted : 25/10/2012 12:55 am
 JoeG
Replaced mine with Enduro brand ones from the LBS earlier this year. They were NOT the Max ones, just the regular ones and cost maybe $5 or $6 each IIRC. Once installed, the passed the "wheel spins real smooth in the hand" test with flying colors.
Posted : 25/10/2012 5:40 am
A pack of ten Ibuprofen tabs costs about eight quid in Zurich airport, which tells you something about Swiss (snd airport) pricing I guess.
I'm sure they're very nicely made from top spec materials, well sealed etc, but tbh, while I really like the star ratchet system in the rear hub (still mad expensive at around £300), I'm not sure why anyone would buy a DT front hub over, say, a Pro 2 unless having matching hubs is very important to you.
I had a set of wheels built a few years ago with a Pro 2 front, 240S rear hub for just that reason. I could see the advantage of the rear hub versus the Hope Pro 2, but not the front. Just my take on it.
Posted : 25/10/2012 9:03 am
Just go to your local bearing supplier with one of the old ones.
You'll be amazed at the markup placed on a standard 2RS bearing the minute it is branded as a "special, top notch, sealed cartridge" MTB bearing.
Expect to pay no more than £4-5 a piece max for something at least as good if not better, if you follow the bearing supplier route.
Posted : 25/10/2012 10:07 am
Thanks chaps 🙂
Posted : 25/10/2012 11:49 am
