Replace 9mm DT RWS,...
[Closed] Replace 9mm DT RWS, alloy QR on my Stumpy
2 Users
I have the DT rws on the front whell and the crappy plastic lever is worn, making if hard to remove front wheel etc any suggestions for a replacement ?
Not impressed with the DT's.
Posted : 19/12/2009 10:19 am
If you mean a std DT Swiss 9mm QR, then any shimano QR, deore to XTR spend as much as you feel you need to, their all great.
covering all the bases:
if you mean a DT Swiss 9mm Thru axle QR, Specialized sell a 9mm thru axle, NC-17 have one on CRC (which got a slagging the other say) or you could try out the SSC one...
Posted : 19/12/2009 10:27 am
