Repairing a camelba...
[Closed] Repairing a camelbak bladder - its leaking
13 Users
I have a teeny tiny little hole in mine - its right at the bottom though if that matters
Are there are any good and easy ways to fix it?
The duck tape repair slowed the leak but that is all.
It is the equivalent of a slow puncture but with water dripping down your back when you ride
Cheers all
Posted : 10/08/2013 8:42 am
Park Tool tyre boot or Zefal equivalent? Chap I know has done exactly this and it's worked fine for him for the last 2 years.
Posted : 10/08/2013 8:46 am
Superglue a puncture patch onto it, which reminds me mine needs doing again!
Should last a good while, oh sand it a bit first too
I've just used a Park glueless patch on mine - tiny leak at one of the seams. (Charge LR reservoir)
Holding up fine so far!
Edit - too slow!!!
Posted : 10/08/2013 8:47 am
bland +1, it ain't brilliant and will come off again over time, but will keep you going for quite a while.
Posted : 10/08/2013 8:48 am
Hardly worth the hassle when you can get a replacement cheap on [url= http://www.ebay.co.uk/sch/i.html?_trksid=p3984.m570.l1311.R3.TR10.TRC0.A0.Xhydration+&_nkw=hydration+bladder&_sacat=0&_from=R40 ]Ebay[/url]
Posted : 10/08/2013 8:49 am
I have repaired one using a soldering iron and a bit of the bladder from an edge
but its a fine line between a fix and a ruined bladder
or solvent adhesive for pvc plumbing pipes should do a permanant repair
Posted : 10/08/2013 8:50 am
 tomj
I had mine replaced free of charge when it started leaking. Something about a lifetime garentee. It was about 4yr old and I had no proof of purchase or paperwork but the outdoor shop I got it from simply gave me a new one and sent the old one back
Posted : 10/08/2013 8:54 am
Camelbak bladders are warrantied for life. Take it back where you got it.
Posted : 10/08/2013 9:04 am
i figured patch may work but was worried about what would happen with the chemical in the glue on the bladder and me consuming it
Trout I suspect your soldering skills are somewhat better than mine and realise what side of the line I would fall on
As it is only small i will try a park patch first
Its second hand and years old so warranty is unlikely to work but might ask Merlin on that.
Cheers all
Posted : 10/08/2013 10:11 am
Buy a Gelert hydration pack from Blacks for 20 quid. They come with a Source inner bladder. The best imho. I wouldn't say repair would be worth it.
Posted : 10/08/2013 10:54 am
Pity the bite valves aren't guaranteed
£5 for something that must cost about 5p to make 😥
Posted : 10/08/2013 11:07 am
My camelbak developed a pin hole leak, for the life of me I couldn't remember where I purchased it.
I contacted the distributor who said they couldn't deal with me direct but a local stockists could help as the middle man, after a local bike shop said they would help out the distributor then said without a proof of purchase they wouldn't honour the warranty. Fantastic!
Posted : 10/08/2013 12:58 pm
Tenacious tape is excellent worked on mine. I did use a bit of superglue directly on the hole too.
Posted : 12/08/2013 10:27 am
