Removing stuck cran...
[Closed] Removing stuck cranks
Evening all,
So being a numpty I forgot to remove the washer from my non drive side crank whilst trying to remove it and as a result my crank extractor now won't go far enough into the crank to remove it.
Question is: Can I remove the drive side of the BB and push the axle out through the non drive side??
It's a generic ISIS BB if that helps any?
Posted : 10/05/2010 8:11 pm
Loosen the crank bolt & ride it. Crank will fall off. Be aware will probably also kill the splines on the BB & crank.
Posted : 11/05/2010 9:13 am
Ah good idea. I think this is what I'll do, not really fussed if it destroys the crank and/or BB, they're being replaced anyway.
Posted : 11/05/2010 9:24 am
