Removing redundant ...
[Closed] Removing redundant brake bosses?
Hi all
I've just acquired a Specialized HT frame and am going to be reconditioning it before building up as a lightweight 1 x 10sp. Question is:
can I remove the old V-brake bosses without causing any issues? If I have to keep them it's not the end of the world but I'd rather lose them if I can..
Steve
Posted : 26/02/2013 5:27 pm
Steel? Aluminium?
Generally no problem angle-grinding them off, and tidying up with a file.
Posted : 26/02/2013 5:30 pm
I've wondered this too but I've never got round to asking. On a Spesh FSR as it happens. And what about a Fox fork?
Are the v brake bosses just welded onto the seatstays without piercing them? How thick is the aluminium seatstay likely to be?
I kind of imagine that the welding might weaken the seatstay a bit but the brake boss reinforces it with the extra material, hence why I've thought it might not be a good idea. Just throwing it into the mix in case, I really don't know.
Fork wise, maybe best not to given that they appear to be cast? Are they made of magnesium as well?
Posted : 26/02/2013 6:04 pm
Its an aluminium rockhopper frame. Looks like they are just welded onto the searstay tube without piercing it...
Posted : 26/02/2013 6:27 pm
I took the rear ones off a Hardrock frame a few years ago, hacksaw followed by some filing smooth and you couldn't tell they were missing after the re-spray. Bike frame still going strong now as my sons hack.
Posted : 26/02/2013 6:37 pm
