removing rear casse...
[Closed] removing rear cassette
trying to get my rear cassette of, removed the first 2 rings but then its completely stuck. Is there any tricks? watched vids on youtube but they show it just dropping off but mine wont budge
Posted : 18/04/2013 6:41 pm
Assume you got the right tools eg whip etc? Soak with plus gas or wd40 maybe.
Posted : 18/04/2013 6:43 pm
yeap already got the lock ring off and the first 2 rings but then it just feels welded onto the freehub body, i have sprayed some wd 40 on it but still not movinging at all
Posted : 18/04/2013 6:49 pm
Hold onto the freehub so it cant spin.
Gently tap the teeth of the rings with something solid (spanner?) in an anti clockwise direction. That should free them up.
Posted : 18/04/2013 6:51 pm
Yep, as above. You've might have this kinda thing going on, depending on the hub/cassette combo;
Posted : 18/04/2013 6:53 pm
You could try poking something with a flat end through the spokes onto the back surface of the cassette and tap with a hammer. Mover round the cassette. I had to do this with a cassette that had dug into a Hope freehub body.
Posted : 18/04/2013 6:55 pm
bullroar - Member
Risky business. You may well end up removing the freehub body rather than the cassette.
Posted : 18/04/2013 6:56 pm
True, but sometimes needs must. It was showing no inclination to come off any other way. Mind, I was gentle with the tapping not a big whack.
Posted : 18/04/2013 7:01 pm
If its a Hope pull on the cassette and you will remove the freehub body. Then you can put the freehub/cassette on the floor (smallest sprocket downwards) and gently push on the larger sprocket to remove it.
Posted : 18/04/2013 8:22 pm
