Removing Hope BB GX...
[Closed] Removing Hope BB GXP spacers for servicing?
5 Users
Hi,
Anyone got any advice on the best way to remove the gxp spacers from a Hope BB for basic servicing and bearing removal.
With the spacer in you cannot remove the outer black seal on the non-drive side. Got some grit behind the seal so won't to clean it out, but need to remove the spacer in order to do so.
Any simple suggestions appreciated!!
Posted : 28/05/2016 10:04 pm
Cut a small slot in before fitting so it's easier to remove...
Posted : 28/05/2016 10:16 pm
Thanks!
But too late, it's been in for 750miles.
Whereabouts are you putting a groove in?
Posted : 28/05/2016 10:47 pm
Just filed a slot in one of the cups, enough to put a screwdriver flat against.
If it's any consolation mines been in for 4,700km and I've nver looked at it or touched it. They are tough buggers
Posted : 28/05/2016 10:51 pm
You can use a blind bearing puller, 20mm will do it IIRC. If you've not got access to one of those, carefully tapping a small screwdriver into the gap, working your way around in between the two will also get them apart, but will make a bit more of a mess of the edges. They're only alloy though, so easy to tidy up with a file afterwards and put a couple of notches in there to make it easier next time.
Posted : 28/05/2016 10:52 pm
 rone
What mint imperial said. I did it like that. Just screwdriver it apart. Takes a bit of time. My spacers are back in a new BB.
No issues.
Posted : 29/05/2016 7:31 am
Pop the cup in the freezer for a few hours. The alloy insert should shrink more than the steel bearing making it easier to get out. Mine came out by hand when I did the swap from gxp to shimano cranks using this method.
Posted : 29/05/2016 8:15 am
