Removing decals
[Closed] Removing decals
What is the best way to remove frame decals?
Posted : 11/05/2013 12:38 pm
Use neat muc-off. Might also change the frame colour and remove anodising though. Hair dryer to soften glue and wd40 or brake cleaner to remove it. Just not at the same time. Ok? ๐Ÿ˜‰
Posted : 11/05/2013 12:49 pm
Warm them up with hairdryer and peel off gently.
Posted : 11/05/2013 1:03 pm
Boiling water is normally the first thing I try.
Posted : 11/05/2013 1:06 pm
Depends if lacquer had been used. If it hasn't then a hair dryer is usually the best thing.
Posted : 11/05/2013 1:13 pm
