Removing copter tap...
[Closed] Removing copter tape from a frame
Any tips on best way to remove copter tape from a carbon frame ? Large sections were put on by previous owner and is now looking a bit tatty and in need of replacing.
Posted : 09/12/2013 9:28 pm
Which frame is it? If it's an On One, don't... The finish is too weak, there's a good chance it'll come off in clumps with the tape. (the bikes are officially incompatible with helicopter tape!)
If it's a higher quality frame, then hairdryer helps massively- speeds it coming off but also leaves less manky glue.
Posted : 09/12/2013 9:30 pm
Argh-sounds a right pain in the arse. It's not an on-one but a lapierre.Might just keep it on if it is a messy and potentially damaging process!
Posted : 09/12/2013 10:20 pm
As NW says, get the Alex ferguson into it, you'll be fine!.
Posted : 09/12/2013 10:22 pm
 JCL
Hair dryer and peel back along the frame instead of up.
Posted : 09/12/2013 10:27 pm
I just pulled all minis off my lapierre then used nail varnish remover on sticky stuff. Then polished it up after. No problem with paint coming off
Posted : 09/12/2013 11:07 pm
