removing bearings f...
[Closed] removing bearings from frame..... grrr.
ok, so i've taken the advice given here and have started to clean the GFs bike.
i want to grease up the bearings, but cannot for love nor money (well, money might work) get the main pivot bearings out of the chainstay.
do i need a tool for this?
Boardman FS if that helps....
cheers
Posted : 24/07/2012 2:21 pm
take the covers off with them in situ and clean/regrease them?
Posted : 24/07/2012 2:22 pm
fiddily job, but unless i can remove them that is what i'll do.....
Posted : 24/07/2012 2:23 pm
you can damage them removing them so it's best not to re-use them once removed.
Posted : 24/07/2012 2:30 pm
cheers for that al!
Posted : 24/07/2012 2:37 pm
conversely, buy a new set of bearings and you dont worry half so much what you have to do to remove the existing ones.
Posted : 24/07/2012 2:42 pm
youu still need to remove the old ones, though.... โ“
Posted : 24/07/2012 3:07 pm
