Removing a stuck cr...
[Closed] Removing a stuck crank
I'm trying to remove the Stout crankset (Shimano Hollowtech II-type) from my Specialized Chisel, but can't get the spindle all the way through the bottom bracket. It gets most of the way through but then gets stuck. I've tried using a punch to tap on the end of the spindle, but to no effect. Any ideas?
Posted : 12/12/2019 5:37 am
Had similar the other day. It was dried mud/muck/grit in the bottom bracket shell. Tip the bike on its side and if you can get the axle part way through, give it a good flush with gt85/wd40. If you've not got enough space, remove the 9ne cup you can access to see what's going on.
Posted : 12/12/2019 6:36 am
Dead blow mallet. Step back and give it a few clouts! None of this tapping nonsense ๐Ÿ˜‰
Posted : 12/12/2019 7:51 am
null
Posted : 12/12/2019 8:06 am
Many thanks for the tip Onzadog. I did what you recommended, then used a piece of wood as a drift, and a plastic-faced hammer to knock the spindle out.
Posted : 13/12/2019 1:42 pm
I've had to use a ridiculous amount of force to get one out in the past, the plastic cup things are remarkably tough, but eventually they gave in to repeated blows with a blunt chisel and a lump hammer.
Posted : 13/12/2019 6:01 pm
