Removing a broken s...
[Closed] Removing a broken screw from wood
[#4619356]
My daughters old cot bed is being sold, there is a screw (wood screw about 1.5mm in diameter?) that has broken off at the head, about 3 threads are showing. I can't get a grip on it with pliers to "wind" it out. Any suggestions on how to remove with minimal damage to the surrounding wood?
Posted : 03/12/2012 8:58 pm
Cut a slot in it?
Posted : 03/12/2012 8:59 pm
Cut a slot in it with a junior hacksaw and screw it out with a flat screwdriver?
Mole grips?
Posted : 03/12/2012 9:00 pm
Hang a marshmallow on it?
Posted : 03/12/2012 9:01 pm
Drill it out and fit a bigger diameter screw?
Pair of cable/tin snip type pliers shoulp give good purchase
Posted : 03/12/2012 9:02 pm
dremel is your friend, tends to be easier to access the screw without damaging the surrounding wood
I usually use the cordless drill. Just tighten the chuck straight onto the remaining screw. Make sure it's in reverse and start slow
Try gripping it with a drill-driver bit.
Posted : 03/12/2012 9:03 pm
hacksaw slot trick doesn't work - screw too skinny
will try locking the chuck on it directly
what is the technique for "drilling out" a screw?
thanks
Posted : 03/12/2012 9:07 pm
Done!
The power of Singletrack, the wife won't harass me for spending time on here now...
It was nickjb's tip that did it. Cheers!
Posted : 03/12/2012 9:11 pm
I could ask my vet 😀
Well he had to remove a broken screw from my dogs leg. It took him 2 days and 2 operations to get it out!
Posted : 03/12/2012 9:30 pm
When i was an apprentice, i snapped a screw in an important job, so the chap i was working with suggested i go to the blacksmith shop down the hill at the steelworks i worked at, get them to heat a half inch bar, red hot, and then bring it back up here, and put it on the screw and the heat will expand the screw.
So i did, but by the time i had got back the heat had transfered down the bar and burnt my hand.
And it didnt work 😳
Posted : 03/12/2012 10:36 pm
project-you believed him?
Posted : 03/12/2012 10:39 pm
When your 16 you still believe in a fat man dressed in a red suit bringing gifts on one day a year.
Posted : 03/12/2012 10:41 pm
And why did you want to expand a stuck screw?
Posted : 03/12/2012 10:42 pm
How would expanding the screw help remove it...
Posted : 03/12/2012 10:43 pm
because when your 16 and learning you believe what people tell you, and everyone knows metal expands, so you believe it will expand in the wood, and then contract, leaving a bigger gap around the screw.
Posted : 03/12/2012 10:47 pm
project,I know your pain.
I remember as a 12 year old in the Scouts being sent to get a "skyhook" to hold a bell tent up while we pegged it out.....
Posted : 03/12/2012 10:55 pm
