Have to remove a 142x12 off one set of wheels and fit to another. I'm sure there are circlips involved just can't quite remember where. That's the rear, front I need to swap 15mm to 20mm.
What's the official method then?
Front 15mm and rear 142 are just push in and held with captive o-ring.
20mm fronts are held in with circlip.
i just went from 20mm to 15mm front, so have a set of 20mm adapters complete with circlips on the go if you need them?
Ta I think I have enough bits. I took the QRs off the rear using the vice technique (with some wood in I hasten to add) so just need to do the same with the 142/10 and 15? Cool.
Probably a bit late but [url= http://www.hopetech.com/webtop/modules/_repository/documents/ProIIEvoFrontExploded.pdf ]this.[/url]
